Old Wed, April 21st, 2010, 06:17 PM
danesjewelry danesjewelry is offline
danesjewelry is on a distinguished road
Default PLEASE HELP
i thought i did everything right &when i plugged it in to my truck it said error 150 call tech support --- now what?
  #12
Old Wed, April 21st, 2010, 06:28 PM
Is it possible that the ignition key was in the OFF position when you plugged the Gryphon back in to your truck? If so, the unit could not "boot" properly.
The solution is simple if this is the case. With the key ON (engine not running), disconnect the OBDII cable from below the dash, and then reconnect. If the PCM's calibration (HEX) code displays, the problem should be resolved and you should be able to load your revised tunes. If not, let us know.
  #13
Old Wed, April 21st, 2010, 06:38 PM
i tried that and nothing changed.it says pcm is not responding. please help
  #14
Old Wed, April 21st, 2010, 06:46 PM
OK, I'll try to attract Bill's attention to this.
Old Wed, April 21st, 2010, 06:55 PM
In touch with Dane and waiting to see if he's got it straightened out.
Info to come shortly...
