Old Thu, May 6th, 2010, 02:52 PM
Which way does the flap need to be (closest to actuator or farther) I think now its closer. i would like to just wire it shut so it cant open is that ok to do?
Also can someone help me get the part numbers for the exhaust donuts for the up pipe. They are leaking. One of the exhaust hangers cam undone so the weight of the echaust was hanging on the turbo. I need all 4 donuts upper and lower for the up pipe. Kragen or Napa had do idea what I was talking about. Both the parts guys asked what a powerstroke was!
Old Thu, May 6th, 2010, 03:07 PM
You want the rod as short as you can get it, tighten it down as much as you can then use compressed air in the actuator port to hook it back up to the gate.
Remember, more boost does not always mean more power.
For the doughnuts you will only need 2, the lowers are a flared type connection.
Go to your Ford dealer for those.
Old Thu, May 6th, 2010, 03:40 PM
To get the wastegate actuator rod as short as it needs to be, you'll have to trim about 3/8" off of the threaded rod.
Yes, the Ford dealer will have the donuts...and they're pretty cheap. My money says you might as well buy new pipes as well because they'll actually be worn out where the donuts ride and they won't seal even with new donuts.
Old Fri, May 7th, 2010, 12:15 PM
On the turbo what is that exhaust flap for on the exhaust side?
Old Fri, May 7th, 2010, 12:43 PM
It is a warm-up valve.
When engine is cold the computer will close that valve in an attempt to keep some heat in the engine for faster warm-up times and reduced emissions.
Some guys are using that valve as a exhaust brake, though I am not sure how effective this is. I do know this can create added backpressure and you run the risk of floating exhaust valves.
Old Sat, May 8th, 2010, 04:45 AM
Do we really need it? Does it restrict flow and can you kit it off?
Old Sat, May 8th, 2010, 11:22 AM
Meh......When I took it off my truck and really did not notice a power increase, but I did not see a difference in warm-up times either.
I would say yard it, it can hurt to try.
Old Thu, May 20th, 2010, 02:56 AM
Originally Posted by epowers777 View Post
So you are saying I can get these injectors (stage 1) for my truck and they will work but I need to get new tunes from php? Doesnt each tune cost money cause I just bought the chip?
So how much would I have to spend in tuning?
If I am called in for smog in California will I pass?
Is the Harness the same?
Better mpg. Like how much?
Sorry for all the questions but I want to be a 100% positive before I spend that money.
In my 2000 F550, 4R100, 4:88, 4x4. I was getting 7.5 to 8 mpg round trip hauling hay, the same run 2-3 times a week. I put stock '94 to '97 90cc single shots, now I am getting 10.5 to 11 mpg that is huge at 1200miles per week.
It dose not have quite the top end power, due to 90cc vs. 140cc, but a lot qiucker and much better low end power. I have not got a chip yet (I have been so busy) I am getting a long with it, ruff idle is annoying.
If the chip doesn't help with the top end power I will, mill the intensifiers pistons for 120-140cc. I want to keep the fuel mileage
Jay 413-222-8286 I got hay for sale
'97 F350 CC, DRW, pickup, 7.3, E4OD, 2wd, 4.10, 405K
'00 F550 reg cab, 11' flatbed, 4x4, 7.3, 6637, 4R100 (soon to be a ZF6), 290k
'97 GMC 5500, getting a transplant, 3.36, sleeper, 350k
Abolish the Federal Reserve, They are the #1 problem.
www.prisonplanet.com
Old Tue, May 25th, 2010, 06:47 PM
Do I need to get friction modifier for my rear dually axle and my front axle they say dana on the caps
Old Wed, May 26th, 2010, 03:55 AM
Only if you have a limited slip or locking differential in the rear. Very unlikely you have a locker in the front. To tell if have a limited slip, jack up your truck so both wheels are off the ground, put in neutral, and spin on wheel if the other wheel spins the same way, you have a limited slip differential, add friction modifier
If the wheel spins the opposite direction, you have an open differential, no friction modifier needed.
