Old Wed, February 11th, 2009, 11:00 PM
Originally Posted by Caforddude View Post
hmmm..That gives me hope of a computer glitch? simple fix... Did you run for any length of time on the stock program before going back to the 87 performance or just load them back to back?
OK, BOTH of you have pretty new trucks, still under warranty. And, you are having similar problems. Caforddude, I doubt NS ran it at stock for long, probably just long enough to "reboot", so to speak. I'd try that and see what happens.
Regardless, though, I don't like what you're both describing, and I don't have a fix. I doubt it's really a problem with the trucks, or the tunes, but some sort of unforeseen interaction/side effect of mixing the two. It happens in computer programming all the time and CAN be fixed, once the cause is found. It's usually something so simple it's hard to see.
I think Bill needs the exact code number to make sense of this. Can you provide it?
(One more thing for everyone: In engineering, if you don't have failures, you're not advancing and pushing the envelope. No one wants engineering to operate that way).
Last edited by Jackpine; Wed, February 11th, 2009 at 11:07 PM. Reason: Added thought about the role of failure in engineering
  #12
Old Thu, February 12th, 2009, 10:48 PM
Caforddude Caforddude is offline
Cali Gestapo!
Caforddude is on a distinguished road
Well I reprogramed it with the stock tune, ran it around the block and then programed my 87 performance back in.
Same issue, same code. Is it possible this is a tune related issue meaning a coding issue not that the tune ruined my truck or more then likely a component issue.
I think for the time being the best course of action for me is to program it back to stock and run it a bit and see if the same problem happenes. From there my logic would be: no problem, tune related..Problem mechanical related....
Agree? disagree?
At 32xxx miles I don't want to wait around to long to see if I need to get it to the dealership before the warranty expires
Aaron
For he is the minister of God to thee for good. But if thou do that which is evil, be afraid; for he beareth not the
sword in vain: for he is the minister of God, a revenger to execute wrath upon him that doeth evil. Romans 13:4
  #13
Old Thu, February 12th, 2009, 11:25 PM
What I really think is that Bill needs about five alter egos so he can jump in and help you figure out the problem.
I can't believe you'd have oil pressure problems on a new truck. And, if that were the case, the problem would not go away when you returned it to stock. Are you trying to adjust "Custom Options" when you set in a program?
If none of this applies, and if there are no problems running at Level 0, I have to believe the tune is causing the problem.
If you agree, I think you should call Bill ASAP.
Old Thu, February 12th, 2009, 11:34 PM
Cali Gestapo!
The only "customizing" I have done with the tuner was to raise the speed limiter to 105 and adjust my tire size. I am going to program to stock in the morning and go from there. I'll keep ya posted.
Aaron
  #15
Old Fri, February 13th, 2009, 12:20 PM
What is curious is that we've been doing minor camshaft timing adjustments since 2004 and we've never run into this problem before. Even more curious is that on trucks with CAIs, we don't do any camshaft timing adjustments because it seems to induce a little bit of droning.
I'll get a look back in the files and make sure we have no camshaft modifications. This should at least eliminate the possibility of that being the problem.
Question: Is there any specific point it sets the codes? During startup... Driving 40 MPH... Under hard acceleration? Anything you can provide will be helpful.
  #16
Old Sat, February 14th, 2009, 03:59 AM
Cali Gestapo!
It does not hit when driving at speed. It hits after I have a driven a distance, short or small and then slow to pull into my garage or drive through a parking lot. It starts to run really rough like it is going to stall but does not quite stall.
I have also noticed it is a hard start now. Previously I would turn the key and fire right up after one crank and now it seems to take several cranks. It has never "not" started but I have been worried a time or two. I thought it is possible the battery was in need of replacing as it is 18 months old or so and with the extreme heat we have out here maybe it had gone dead but I am not so sure now. I was up in the mountains today and my truck got snow covered and sat in 24* weather for 6 hours and fired right up on the first try, so I think maybe the battery is ok.
My brother in law is a mechanic and said he thought he had heard of a TSB regarding this very issue so I am going to explore that avenue also.
I'll keep ya posted and try to answer any questions to the best of my ability.
Aaron
  #17
Old Wed, February 18th, 2009, 09:45 AM
Cali Gestapo!
SO quick question. I had gotten a p1000 code and was told somewhere else that is going to be a warranty breaker when I take it in to the shop?
Any ideas if that would be true or if there is a way to get rid of it?
Truck goes in the sho today and has been returned to stock for several days
Aaron
  #18
Old Wed, February 18th, 2009, 12:59 PM
Grabber523's Avatar
Grabber523 Grabber523 is offline
Your Mom's favorite :D
Grabber523 is on a distinguished road
p1000 means your PCM is witing to complete a drive-cycle. If they see that code at the dealership it tells them one of 2 things:
1. you just disconnected your battery, no big deal
2. you have re-flashed your PCM, big deal
I'll try to find the drive cycle procedure from my Mustang Forum and post it up.
  #19
Old Wed, February 18th, 2009, 01:01 PM
Grabber523's Avatar
here is what I could find on the driving cycle procedure, here is the link Ford Motor Company Driving Cycle (from Moddedmustangs.com)
Drive Cycle Procedure
Purpose of
Drive Cycle
Preparation
1. Install scan tool. Turn key on with the engine off. Cycle key off, then on. Select appropriate Vehicle & Engine qualifier. Clear all DTC's/ Perform a PCM Reset.
2. Begin to monitor the following PIDs: ECT, EVAPDC, FLI (if available) and TP MODE.
Start vehicle WITHOUT returning to Key Off.
3. Idle vehicle for 15 seconds. Drive at 64 Km/h (40 MPH) until ECT is at least 76.7°C (170° F).
4. Is IAT within 4.4 to 37.8°C (40 to 100° F)? If Not, complete the following steps but, note that step 14 will be required to "bypass " the Evap monitor and clear the P1000. Engine warm-up and provide IAT input to the PCM.
HEGO
5. Cruise at 64 Km/h (40 MPH) for up to 4 minutes. Executes the HEGO monitor.
6. Cruise at 72 to 104 Km/h (45 to 65 MPH) for 10 minutes (avoid sharp turns and hills) Note, to initiate the monitor: TP MODE should =PT, EVAPDC must be >75%, and FLI must be between 15 and 85% Executes the EVAP Monitor (If IAT is within 4.4 to 37.8° (40 to 100°F))
7. Drive in stop and go traffic conditions. Include five different constant cruise speeds, ranging from 40 to 72 Km/h (25 to 45 MPH) over a 10 minute period. Executes the Catalyst Monitor.
8. From a stop, accelerate to 72 Km/h (45 MPH) at 1/2 to 3/4 throttle. Repeat 3 times. Executes the EGR Monitor.
9. Bring the vehicle to a stop. Idle with transmission in drive (neutral for M/T) for 2 minutes. Executes the ISC portion of the CCM.
10. For M/T, accelerate from 0 to 80 Km/h (o to 50 MPH), continue to step 11. For A/T, from a stop and in overdrive, moderately accelerate to 80 Km/h (50 MPH) and cruise for at least 15 seconds. Stop vehicle and repeat without overdrive to 64 Km/h (40 MPH) cruising for at least 30 seconds. While at 64 Km/h (40 MPH) , activate overdrive and accelerate to 80 Km/h (50 MPH) and cruise for at least 15 seconds. Stop for at least 20 seconds and repeat step 10 five times. Executes the transmission portion of the CCM.
Misfire & Fuel Monitors
11. From a stop, accelerate to 104 Km/h (65 MPH). Decelerate at closed throttle until 64 Km/h (40 MPH) (no brakes). Repeat this 3 times. Allows learning for the misfire monitor.
12. Access the ON-Board System Readiness (OBDII monitor status) function on the scan tool. Determine whether all non-continuous monitors have completed. If not, go to step 13. Determines if any monitor has not completed. Pending Code Check and Evap Monitor "Bypass" Check
13. With the scan tool, check for pending codes. Conduct normal repair procedures for any pending code concern. Otherwise, rerun any incomplete monitor.
Note: if the EVAP monitor is not complete AND IAT was out of the 4.4 to 37.8° C (40 to 100° F) temperature range in step #4, or the altitude is over 2438 m. (8000 ft.), the Evap "bypass" procedure must be followed.
Proceed to step 14. Determines if a pending code is preventing the clearing of P1000. Evap Monitor "Bypass"
14. Park vehicle for a minimum of 8 hours. Repeat steps 2 through 12. DO NOT REPEAT STEP 1. Allow the "bypass" counter to increment to two.
  #20
Old Wed, February 18th, 2009, 07:33 PM
Cali Gestapo!
Well no firm diagnosis yet but they are telling me they think both came are bad as they were getting codes from both sides when they were driving it with there fancy computer hooked up to it. They said posibbly an oil change issue if using poor quality filters something inside the filter might get broke off inside and block some filter
As of now they said it looks like warranty covered cam replacements. It I will let you know for sure when I get the final word
Aaron
