Old Tue, July 27th, 2010, 06:49 PM
secstang03's Avatar
secstang03 secstang03 is offline
secstang03 is on a distinguished road
Default PCM Code
Spoke with Cody yesterday about ordering the Pheonix Chip. I am currently trying to locate my PCM Calibration code. The truck currently has an Edge programmer on it, I plugged it in and didnt have any luck seeing the code.
On the wiring harness that plugs in to the computer, there was a sticker for recal. It has the numbers F7TF-TB
There is also a cal code on the side of the drivers door that says 6-90A-R02. This number/letter combo seems to be correct from what I have read, but it was on the door. Everyone says it should be on the computer.
Does anyone know if either of these are the codes I need to order the chip?
1996 F250 7.3L
Old Tue, July 27th, 2010, 11:38 PM
F-127's Avatar
F-127 F-127 is offline
Tuner novice
Hey there,
Most of the time people find a 3 letter-1 number code (ex SOD4) on the fenderwell side of the computer, can be hard to see without a mirror and light, even then you might be reading backwords, so its not always easy to get. However, the one number you gave "F7TF-TB" matches up with a PCM code on a calibration list. The PCM code would be TDE1 with that number you gave, which would make sense if you have a '96 auto with a dealer PCM recalibration. Your actual PCM code on your computer might not be TDE1, but it would probably be in the same hardware family for being compatable with a Pheonix chip. I would say you could probably order your chip with the F7TF-TB number, but if you could find the PCM code in addition that you could also have handy when you order you would be golden! Hope this isn't too confusing!
Thomas H.
Old Wed, July 28th, 2010, 08:12 AM
secstang03's Avatar
Nope, not confusing. Cody also responded in my other thread and gave me the same calibration code that you did. Thank you for your help!
Old Wed, July 28th, 2010, 11:29 AM
Closed........
Double thread.
