Old Tue, July 27th, 2010, 08:18 PM
ABLAIR07 ABLAIR07 is offline
ABLAIR07 is on a distinguished road
my budy turned the truck on when it was program a tune in the last time . so i took it to ford they flashed it worked fine. i retuned it work good for a bit now i cant reset it to anyof the tunes says f2 missing fille
  #12
Old Tue, July 27th, 2010, 08:26 PM
Are you sure it wasn't either a D2 error or F1 error?
If it was an F1 error then try this:
1. Leave the ignition key in the ON position.
2. Disconnect the Gryphon at the OBDII port.
3. Plug the Gryphon back into the OBDII port.
4. After getting to the main screen, wait 15 seconds for needed parameters to be loaded.
If it was a D2 error then we can almost be sure that an important part of the cable or the programmer failed.
Does the programmer light up and show the little parameters when your driving?
Last edited by Longshot270; Tue, July 27th, 2010 at 08:36 PM. Reason: posted double
  #13
Old Tue, July 27th, 2010, 08:33 PM
i turn it on it says unable to locate splash try to tune it comes up f2 missing file but all the gages work on it when im driving just cant scan it for tbl codes or change any thing
  #14
Old Tue, July 27th, 2010, 08:43 PM
Ok, this is a new one for me.
Try taking it out of the truck and updating it. If you dont already have it, download the program Pegasus from the PHP website.
Power Hungry Performance - Customer Support
Completely install pegasus before you plug the programmer in.
Once you have pegasus installed and the programmer is in, go to Gryphon Update Manager and go through the steps to resetting the programmer.
Old Tue, July 27th, 2010, 08:51 PM
im not sure witch one it is?
  #16
Old Tue, July 27th, 2010, 08:55 PM
Here is a portion of a screen shot that shows the link from the PHP support page with the download.
Let me know if this helps.
Old Tue, July 27th, 2010, 09:09 PM
the gryphon icon is the only one not lit up i cant go to it
  #18
Old Tue, July 27th, 2010, 09:15 PM
Did you go to the "PEGASUS™ and PHOENIX FLASH (FU)™ SOFTWARE " and click on the white bar below it? That is a drop down menu. Next select "Pegasus Update Client". Keep an eye out for a yellowish bar to appear towards the top of the screen saying Internet Explorer(if that is what you're using) is blocking stuff.
Old Tue, July 27th, 2010, 09:17 PM
everything seams to be installed i can go to all the fuctions but that one
  #20
Old Tue, July 27th, 2010, 09:19 PM
So you've got pegasus installed?
If so go get the programmer and plug it in. You should be able to go to Updates>Gryphon Update Manager
