Old Thu, August 19th, 2010, 09:06 PM
LonestarROB's Avatar
LonestarROB LonestarROB is offline
Lonestar Legend
LonestarROB is on a distinguished road
My truck seems to have developed a similar issue as well. When it sits idle for a few seconds, it drops and "shakes" ever so slightly and then idles back up. This just started a week or 2 ago.
Old Wed, September 29th, 2010, 06:21 PM
x2mosg's Avatar
x2mosg x2mosg is offline
x2mosg is on a distinguished road
Rob, Clean your MassAirFlow Sensor first. I konw you're dumping a oil/gauze filter and that could be the problem. The oil will dirty up the MAF and cause rough idle issues. If that doesn't fix it dig deeper.
David
'05 F150 FX4 Flairside
2" AS Leveled
DI/DO 50 Series Flowmaster
Gotts Mod Intake (my version)
295/70/18 Terra Grapplers
Wish List
Gryphon Programmer/Custom Tunes
Firestone air bags
Wheels
Gears
Old Wed, September 29th, 2010, 09:15 PM
Lonestar Legend
It's gone. Just eventually went away.
Old Wed, September 29th, 2010, 10:32 PM
x2mosg's Avatar
Check the other thread. Posted the MAF cleaning link.
David
2" AS Leveled
Wish List
Firestone air bags
Wheels
Gears
Old Wed, November 3rd, 2010, 07:45 PM
clayton87 clayton87 is offline
clayton87 is on a distinguished road
Take off your throttle body ( four bolts) and clean it out you'd be suprised how dirty it gets, clean it with some carb cleaner and some rags, and also while your at it take some brake cleaner(electrical cleaner) to your maf sensor ,thats it let it all dry , reset your pcm with a tune, and you should be good
Old Sat, November 6th, 2010, 11:02 AM
Watch what fluids you suggest to clean the TB with some of them may not be O2 senser safe...
Old Mon, November 8th, 2010, 12:45 PM
I used the stuff from napa auto -intake medic-haven't had any problems in years.
Old Mon, November 8th, 2010, 01:39 PM
The biggest concern is not so much what you use, but that you either remove the throttle body before you clean it or use a rag sprayed with cleaning solvent to clean the throttle body. What you DO NOT want to do is spray solvent down the intake. Most of the manifolds are plastic nowadays and the solvent will not be very friendly.
