I was curious how large cc wise an A code injectors can be built. Reason being it seems to me the higher injection pres of the A code would up the mileage and perfromance of an engine even though you would need more oil. Especially if you had a weak pump and were going to replace anyways. Would an 200cc/100% full A code not out perform a hybrid the same size? How much more oil would the A code need?
WHEN IN DOUBT FLOOR IT! ![]() IF IT'S TOO LOUD YOUR TOO OLD! ![]() 99.5' F-250 EXTCAB 4X4 6SPD 4" LIFT 35" TIRES 3.73 GEARS K&N INTAKE, GTP38R W/TURBO MASTER WASTEGATE CONTROLLER, 203DEG THERMOSTAT, EVO II,AND MBRP COOL DUALS EXHAUST NO MUFFLER |
Yes you will loose injection "quality" with lower injection pressures, but gain the speed to deliver more fuel. Another benefit is that big oil systems are not always necessary with the Hybrids, that make it a bit easier on the wallet. |
I am sure you can have 450HP with some A's, but it wont be as easy as you could with a set of Hybrids. |
Lets say you have a backhoe that the hoe wont lift as much as it should. If you put a flow meter inline on the main pressure hose coming out of the pump you can check pressure and flow. The system will have a min spec of what GPM at a set PSI the pump should maintain. Lets say it should be 50GPM@3500PSI you check it at no load (usuaully less than 100PSI) and it's pumping 60GPM. Looks good at first, but the GPM starts drop in as you increase the load (flow meters have built in adj restrictor to load systems) the gpm drops. It's possible that the flow completely stops 0GPM and the pump be making say 2500PSI the machine will stall. Thus can you have pressure with no flow and the system still work till you till the load gets to heavy. Make sense
Not trying to argue, but lets take a look at a basic example.......
Lets look at some other definitions of pumps and pressure...... Taken from Hydraulic Pumps Quote:
All of that is very true and completely blocking flow is the ultimate restriction. When you shut off the nozzle on that garden hose there is still pressure in that hose behind it even though there is no flow ie you have pressure with no flow.
Not trying to be smartass just trying to get you to see my side of it.
Lets go back again and see if we can figure this out.......
Having fun yet?
I think we have gotten away from the subject a little. The only point I was trying to make was that if 3000PSI is demanded from your HPOP the HPOP doesn't know or care which injector is in front of it. The HPOP will pump as much volume as it takes to try and maintain that 3000PSI which will be the same as the intensifier pistons are the same. It's the additional oil flow or volume the A code will need to maintain that 3000PSI for a longer time because its barrel is smaller and the plunger must travel farther to inject the same amount of fuel and also taking more time that will hinder it. There by flow not so much as pressure is the problem on high HP engines ,but shouldn't be as much a problem on lower HP engines. Of course if the HPOP can't keep up the pressure will also be low. I was wondering at what point or HP range is the Hybrid truely at an advantage. I know at stock levels the A is best and at 600HP+ Hybrid is better, but where is the split between the two as to which one is better?
Agreed! That is probably a question better suited for an injector builder, or someone with some time on a flow bench. Sorry I am no help.
