Old Thu, January 20th, 2011, 11:58 PM
hampsterzone's Avatar
Come Get Some
I see said the blind man! Makes sense to use an average. I will do that. I can't use my odometer because it will not read anymore. I posted about it but no one has replied. LOL anyways, thanks for everything.
2nd place is 1st's loser!
Old Fri, January 21st, 2011, 12:00 AM
Oh yeah, you replaced your dash. I dont know what to tell you on that one besides check your harnesses again. Might try the larger forums.
Old Fri, January 21st, 2011, 12:15 AM
Come Get Some
Thanks, I do appreciate it. My odometer does not read out anymore as per my post. So that idea is out of the question. But the average suggestion makes every bit of sense. I will do that.
Old Fri, January 21st, 2011, 12:39 AM
Years ago before GPSs and such, that is exactly what I would have done.
Here is the secret to reliable science. Always take multiple samples.
Old Fri, January 21st, 2011, 11:33 AM
Bill SHOULD include your new Gear Ratio (GR) and Tire Size (TS) in your tunes. But, the TS is a bit of a WAG. Personally, I think you can refine the TS using a speed readout on the GPS and compare it with a speed readout on the Gryphon (not the dash speedo - which always reads faster due to mechanical errors).
If you stabilize the speed on the highway (70-75 mph is a good speed) and find a TS that gets them to match, you're golden. I've found my GPS speed stabilizes within less than 3 seconds at a constant speed.
Longshot, I'm going to "quibble" with your suggestion of 2770mm, it seems too large. A tire diameter of 35" has a circumference of 2793mm. Reducing that by 3% for squish give me 2709mm.
But, regardless - pick one of those values as a starting point. If your Gryphon speed indication is too fast, reduce the TS. Increase the TS if the Gryphon speed is too slow.
And, I'm sorry but I'm not coming up with any thoughts about your odometer.
Old Sun, January 23rd, 2011, 09:59 PM
Come Get Some
Thanks!
