Old Sun, January 30th, 2011, 09:57 PM
hampsterzone's Avatar
Come Get Some
Opinion considered! Forced air induction is too risky and potentially harmful to engines. With all that being said, what do you think of my mods? Have you done the same? I don't like under drive pully's because of the alternate problems and higher idle rpms needed. I don't think I have anything else to do performance wise. All I want now is an 8" lift. LOL
2nd place is 1st's loser!
Old Sun, January 30th, 2011, 10:17 PM
Low boost can be done with no problems. Even small amounts of spray can be done to a stock engine. You just run into the problems of using it too often. An engine doesn't like to run at WOT all the time when it is connected to a 5000+ pound truck.
Your list is more impressive than I can afford, so no, I haven't done many of them.
Stuff like the intakes can be experimented with at a minimal cost and a little common sense. Take anything I say with a grain of salt because I'm no mechanic and certainly not an expert. I just type my best opinion and am willing to learn from the parts that are wrong. That is why these forums are so great. Technically I should be asking you for opinions, I'm one of the youngest members of this forum.
Old Sun, January 30th, 2011, 10:48 PM
Come Get Some
Thanks... I hope I don't ever come off as pompous or seem to brag about my mods. It has literally been a dream of mine to have done everything I have. I have never owned a new truck! And trust you me, I would love a new Raptor w/ the 6.2 liter. It has become quite addictive being a member of this forum. May I inquire how you became a moderator? I would love to be one. LOL Seriously! I am very interested in helping others out on this forum.
Old Sun, January 30th, 2011, 11:10 PM
Oh no you didn't. I would love to have a raptor version of my truck...but it means I'll just weight the options for mine because I can't even afford to rebuild my dirt bike.
We all got here just by helping out. Us moderators are volunteers, we dont get paid a penny.
Read this, things will make more sense (hopefully)...Power Hungry Performance - About Us
Old Sun, January 30th, 2011, 11:23 PM
Come Get Some
I know you guys are volunteers, and I see that you guys are always quick to reply and help out. I think it would be super cool to be a moderator. But then again, I can help much the same w/ or w/out the title. My beautiful wife says I can have a new Raptor after I pay off this one. Which means, less mods and more principle payoff. Is that before or after the 8" lift? Haha!
Old Mon, January 31st, 2011, 08:12 AM
Skip_1074 Skip_1074 is offline
Skip_1074 is on a distinguished road
Default Disclaimer: I am no expert nor a mechanic!
I wanted to post on this topic from the minute that I saw it, but haven't been able to actually get on a computer to do it, so here it goes which is actually better for me. I hope that I have enough understanding to help, but we'll see. Sorry if I chopped something out of your posts that was important, but I was just trying to get the points/details.
Originally Posted by hampsterzone View Post
Well, a very good friend who is a mechanic of 25 yrs, gave me the low down. CAI's are the best for adding horsepower. The Gotts mod is cheap and effective but not as much as CAI. Moving the MAF sensor doesn't cause lean codes. It reads air flow no matter where it is. Lean codes come from custom exausts not CAI. Low back pressure cause the lean codes.
Which makes sense cause I never had a lean code with my edge and CAI alone.
But when I did headers and true dual exhaust I saw lean codes on bank #1 and bank #2.
While I don't mean to discredit your friend, I would like to know what he is basing his information off of. I've been studying, working on, mod-ing, planning vehicles for over 10 years now (import cars and trucks to domestic gas and diesels) and it just seems a little different from the norm from my research. I admit my lack of understanding is in the electronic aspect of engines and how some of the sensors play a role, but
I think Longshot addresses the movement of the MAF sensor and/or its coexistence with a CAI as well as the lean environment in the next quote very nicely. I will expand more in a few.
You never experienced a lean code with a CAI and the Edge because even though the Edge wasn't calibrated specifically for the CAI that you were using, it had altered your fuel trim already thus providing more fuel to the engine. That being the said, without actually knowing the strategies, or understanding them for that matter, that Edge uses (and many other factors such as tune used, octane used, CAI brand and tube diameter at MAF sensor in comparison to stock), I believe that your the Edge kept your A/F ratio with CAI somewhere around the what the stock programming had.
I will also try to explain the exhaust setup's existence in a few. I'm trying to keep to one point at a time.
The commercial "cold" air intakes use a larger diameter pipe than the stock sensor housing.
This is a picture that demonstrates what a cross section would look like. The blue area is what the truck calculates for and the red area is what is not calculated because of an aftermarket intake that is larger than the stock housing.
With the larger diameter, the air will flow at a different speed. If you were to bring in 60 grams/sec of air it will flow faster in the narrower tube. Higher air speed, lower wire temperature.
On a stock truck the sensor is calibrated for the stock fluid area (blue). Any result you get from the MAF sensor can be calculated into an accurate physical volume. If you increase the diameter, you change the air speed, you change the reading and in doing so, you change how much air an electrical value represents. This is where custom tunes come in and we've got plenty of threads about that.
So the sparknote version:
Yes, the MAF sensor will read airflow no matter where on the intake track it is located, but that does not mean the reading will be accurate.
When you increase the diameter of the pipe the air does not need to move as fast to move the same volume. The slower air velocity will read on the sensor as the wire being slightly warmer, making the resistance slightly different. When the value is different the truck fuels different.
As I stated, I think this is a very good explanation. I honestly can't explain it better, but can only maybe elaborate upon it. I know that it is more technical then what I am about to explain. My mind thinks in numbers, so please forgive me.
If you have a two hoses and pretend that the small one is stock and the larger is a CAI...lets say a 3" (7.07 square inch cross section) and 4" (12.57 square inch cross section)...and a sensor that is 1" by 1" (1 square inch) that extends into them. The sensor is designed to take a sample from 14.14% of the 3" hose and that is needed to provided accurate flow calculations, but when placed in the 4" hose, it only takes a sample from 7.95%. That means only 56.22% of the required sample is being provided for the calculations.
If this doesn't make sense, let me know, but I hope that it helps better explain the situation. I have a post from another forum that is about 880 words that really breaks it down if anyone wants to read it.
Any thoughts regarding exhaust causing leaner conditions? I would love to hear your opinion. (anyone's for that matter).
Okay, on the the exhaust and addition to an Edge and CAI. "A chain is only as strong as it's weakest link." This works two ways on an engine:
1. You can only suck in as much air as the exhaust system can expel.
2. You can only expel as much air as the intake can suck in.
My understanding is the first was the case with your truck. The addition of a free flowing exhaust freed the engine's ability to take in more air from the CAI already installed. As stated before, I believe that the Edge held your A/F ratio similar to stock, but I also believe that the tune did not provide a large enough increase in fuel for both the CAI and exhaust system you added, thus causing the lean issue.
Where I am not sure how O2 sensors play into the equation. I know that some vehicles (don't remember which ones right now) are very sensitive to changing them as well as changes in their placement. I don't know if this played any part in your situation or not, but I figured that I would toss that out there too.
Longshot, don't be bringing age into the equation here. We each have one goal here, to exchange information and learn from the information someone else provides that we didn't already know. But since you brought it up...I'm only 27.
I've spent well over an hour typing this and I think I confused myself now, or maybe its just the fact that I have been up all night working and still have another 4+ hours to be up. If I missed anything, you have questions, or whatever, please let me know. I'm off to go play with some numbers to waste time. After I've slept, I'll try to post some interesting just for and giggles facts that I'm going to try to derive, now I've just got to find the excel files I have.
2010 F150 XLT SuperCrew 4x4, 6.5' bed
5.4L, 6spd, 3.73LS & Max Tow Package
Gryphon CTS, Custom 87 Performance tune
"Stupid Plastic Snorkle Delete" (a.k.a. Gotts Mod)
Line-X bed & Highway Products "Silverback" toolbox
Old Mon, January 31st, 2011, 09:05 AM
Good post Skip
But I want to add to a few of your points.
That is a good observation. One thing that is recommended for people with CAIs are the canned tow tunes. They are written with a richer A/F ratio and it helps counter act the lean effects.
But you also have to remember every truck runs a bit different so there is a bit of luck involved. He was lucky and no codes came up.
I bolded the part that I usually find important. Air is a fluid and fluid dynamics is a tricky subject. A more important comparison would be the velocity of a specific amount of air through different sized pipes. The engine is nothing more than an air pump so the air flow that is entering can be calculated mathematically. With the narrow pipe the sensor might read 65 grams/sec but with a larger pipe it might only read 55 grams/sec. That difference is what causes the lean condition because the truck fuels for 55 g/s instead of 65 g/s.
Here is where the O2 sensor comes in. Their purpose is to make sure the truck is running around stoic for emissions purposes. The O2 sensor will attempt to correct the issue but it does not have nearly as much influence when the MAF sensor is still operating within the predetermined parameters of "working sensor". When these two sensors do not agree enough you have rich and lean codes. But there are many other sensors that contribute to the codes.
I can't say for sure but this echos the same effect as the CAI to the MAF sensor if you go to a larger pipe diameter with the same O2 sensors.
Only 27? You guys crack me up. Try being 19 a month ago, being 18 when I got promoted to a jr mod. You have to realize that, regardless of it being important or not, many people think age does make a difference. Doesn't help that I look 16 and have no official mechanical experience. My dad still refuses to let me work on my truck when I'm home. I was using the age as an example why the forums are good at building intelligent discussions because you can't assume somebody doesn't know what they are saying based on appearances, as I've encountered many times in face to face discussions.
Thats ok, I spend a few hours typing that long post too because I was watching a movie.
I usually go fishing to waste time...but whatever floats your boat.
Old Mon, January 31st, 2011, 12:19 PM
Now that you youngun's have finished talking - and making VERY good points, in my opinion, I want to throw in this one last observation:
The MAF sensor is nothing more than a heated wire whose resistance changes as its temperature changes. As air flows over it, the wire is cooled and the voltage drop across it is modified. This voltage drop is what is interpreted by the PCM as a quantity of airflow - more air molecules hitting the wire, more cooling (which is what Longshot said in a different way). Notice if the area around the MAF sensor is increased, more air gets by without changing the number of molecules hitting the wire, and, the mixture is potentially leaner.
But, we have O2 sensors in the exhaust that report the result of that leaner mixture to the PCM and it tries to compensate by adding fuel. As long as the mixture is not TOO lean, it can do this and you don't get codes, but, you're now operating near one end of the design envelope (instead of near the center).
However, as Longshot also said (not bad for a "fish guy"), fluid flow is tricky stuff indeed. As flow velocity increases, static pressure decreases, so, the air becomes less dense. The effect of having a constricted intake snorkel forces the airflow velocity to increase to fill the cylinders at a reduced pressure! This is essentially the effect you get when driving at altitude. The MAF sensor "sees" all the flow though (as long as it fills the throat), so all is well. Opening the intake snorkel to 3" (an increase in diameter of 1" in my truck), changes the "choke point" cross sectional area from 3.142 sq inches to 7.069 sq inches! This doubling+ of the intake area greatly reduces the intake flow velocity and increases the density of the air charge - without "fooling" the MAF sensor since it still "sees" all the air flowing around it. (Effectively, we've suddenly taken the truck to below sea level atmosphere conditions and it can make more power.)
Anyway, this is how a 70-year old sees things.
Old Mon, January 31st, 2011, 02:02 PM
ticopowell's Avatar
Grown-up in training!
Haha well I am not the oldest or the youngest here(25), but I do think its great that we can all have fun joking about ourselves while learning stuff .
I just wanted to add a clarification to what I posted before, I am not interested in aftermarket MAF's, mine works fine and im never gonna have a monster machine that needs that much airflow. I was just pointing out that the diameter around the actual sensor stays the same on the CAI's that I have dealt with, therefor the fact that the rest of the pipes change wont have a huge effect on the reading.
also another thought... just because you arent getting a lean code doesnt mean that you arent running slightly lean... or the same with a rich code just my thoughts
Old Mon, January 31st, 2011, 07:37 PM
Are you sure they weren't larger or a different shape around the sensor? If not then you aren't gaining anything running them besides the looks. You must consider your point of peak restriction as that will slow down air movement and change the absolute pressure from there to the cylinders.
