Old Wed, May 11th, 2011, 11:46 PM
ToMang07's Avatar
ToMang07 ToMang07 is offline
That guy...
ToMang07 is on a distinguished road
Originally Posted by 907DAVE View Post
One thing I do with mine is to remove the box and use that small grounding tab (on the lower 7MM bolt) to keep the PCM up against the firewall. This also acts as a case ground for the PCM.......whether its necessary or not - I could not tell you.
I fashoned a little "Z" shaped brackt... attached a rubber runner on the PCM mount and a rubber "arm" on the bracket....and used the lower screw on the stock mounting bracket as well. I think I will go get a pic... could come in useful!...
02 F-350 Super Duty SCSB 4x4 SRW 7.3L TD, DIY-I, PHP-6 Phoenix, 4" Turbo-Back 409 MBRP, Glowshift 3 in 1, Fisher 8' MM2
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery."
Old Thu, May 12th, 2011, 12:03 AM
ToMang07's Avatar
That guy...
Old Thu, May 12th, 2011, 06:55 AM
OneMeanStroker OneMeanStroker is offline
OneMeanStroker is on a distinguished road
Very nice!!!
SHAWN
2000 F 250 CC LB 4x2, 6-sp, FU chip, WW, Turbomaster, Overboost Annihilator, BHAF, 35" ProComps on Flat Black 18" Mazzi Hulks, 4" DP, 5" Exhaust with muffler delete, ZooDad, Custom mesh grill, Boost, EGT, and Trans temp gauges.
2005 EX Limited, 4x4, CAI, NITTO TerraGrapplers on custom wheels, 3.5" DP, 4" Exhaust with muffler delete, Boost, EGT, and Trans temp gauges. GRYPHON.
Old Thu, May 12th, 2011, 09:11 AM
You go a lot further than I do.
The 2000 PCM is flopping around; only being held in place by the wiring harness. The PCM in the 1995 is resting between the underhood fuse box and brake master cylinder.
Old Thu, May 12th, 2011, 11:59 AM
I did this mainly so I can get the connector back into the PCM without any assistance, and seems to work well.
Old Thu, May 12th, 2011, 12:13 PM
ToMang07's Avatar
That guy...
Bingo!
Old Sat, May 14th, 2011, 12:32 AM
wood4heat's Avatar
wood4heat wood4heat is offline
wood4heat is on a distinguished road
I got the check I've been waiting on today. This weekend I'll hunt down my PCM code and by Monday I'll be placing my order. BIG POWER HERE I COME!!! Or at least better power.
Old Sat, May 14th, 2011, 02:11 PM
dietoremain dietoremain is offline
dietoremain is on a distinguished road
mine chip is held in by a whole lotta electrical tape.
2002 7.3 F250 Supercab Shortbox
DIY intake
CCV dumped
Autometer gauges
WW/ATS 1.0 exhaust housing
Hutch/Harpoon in tank mods/hpX line
AIH delete/ebpv delete
TruCool trans cooler
Straight piped
PHP FU
Old Sun, May 15th, 2011, 07:55 PM
wood4heat's Avatar
wood4heat, what is your PCM code? Longshot270 had some really great information there, but as far as the 4R100 is concerned it is a little off....
Under normal acceleration, the TCC is commanded to apply in 3rd gear at some point (Depending on PCM code, which is why I asked for it).
Just took a look, my code is VDH5. Does that tell you anything?
I would also still like to know if the 3-4 shift can be cleaned up without changing the 1-2 and 2-3 shifts.
Would it be best just to call in before filling out the order form?
Old Sun, May 15th, 2011, 11:34 PM
cj45lc cj45lc is offline
I'd give them a call just to make sure you get all your questions answered. That was one of the things that really impressed me, no matter how dumb or trivial the questions I asked I got great answers without being made to feel like a dumba$$...lol. They are really a great outfit to deal with.
