Old Tue, August 16th, 2011, 11:36 PM
Default Another gem in the shop this week.....
Early 99 Powerstroke. Regular cab dually with a 6-speed. Customer says that it starts fine in the mornings but if you take off and drive it immediately or before the temperature gauge goes above the first line, it will lose power and die. Restarts take some coaxing.
Well, a good technician always tries to duplicate the concern. Well, yep, it did it. I got 1/4 mile down the road the following morning and sure as heck, it starts sputtering and losing power until the pedal is dead and I coast to a stop. Cranks fine and eventually starts after about 10 seconds. It's missing and carrying-on for a few seconds and after about 10 seconds runs fine again. I turned around and headed back to the shop.
The following morning, I checked the oil level before I started it: there was nothing on the dipstick. I hooked up the scanner knowing at this point what was going on. Sure as the sun rises, same thing. This time, the scanner caught the ICP dropping to nothing and the IPR going full tilt.
I just find it hard to imagine being able to run a truck for 10,000 miles on an oil change, never checking it, and only doing something about it once you get so frustrated with the truck stalling every time you drive it........The engine had only 5 quarts of oil in the pan. 15 quarts of oil later and purging all of the air from the high pressure oil cavities in the head and it's back in business.
Oh, and since it's an E99 with a broken tab on the air box, the compressor wheel is nearly gone and it turns over REALLY fast while cranking. To make matters worse, the guy uses the truck for his fencing company so it LIVES on dirt roads and cow trails. The intake tube was lined with DIRT...not dust...DIRT. SAWEEEEET!
Old Wed, August 17th, 2011, 07:45 AM
shotgun's Avatar
shotgun shotgun is offline
Gryphon CTS
Hope he's better at building fences than maintaining vehicles (that provide/support his job).
Old Wed, August 17th, 2011, 09:00 AM
Sadly this does not surprise me. I've seen it plenty of times down here.
Old Wed, August 17th, 2011, 09:16 AM
I see alot of "farmed" pickups up here also.....its sad people treat their vehicles like that and then expect them to run perfectly.....
Old Wed, August 17th, 2011, 12:35 PM
Good Lord! I'm surprised it could run at all.
Old Wed, August 17th, 2011, 01:05 PM
Ran ok when warm....but then again the oil would drain back to the pan fast enough to keep the pickup tube somewhat submerged in oil when it was warm.
Old Wed, August 17th, 2011, 08:33 PM
F-127's Avatar
F-127 F-127 is offline
Tuner novice
Wow... I bet he thinks he's got a REAL good starter in that one.
Thomas H.
Old Thu, August 18th, 2011, 08:29 AM
cj45lc cj45lc is offline
talk about getting your money worth out of a oil change, I hope you billed him good...lol
Old Thu, August 18th, 2011, 12:38 PM
TwinTurbo's Avatar
TwinTurbo TwinTurbo is offline
Stock Sucks!
TwinTurbo is on a distinguished road
Job Security! I overhauled a tractor for a customer once, wrote the hours down on the filters and told them they needed to change it between 30 & 50 hours the first time. I stopped by to see how everything was going and the filters i put on were still on and the hour meter had around 300 more hours on it. Warranty Voided
Put a Turbo on it!!!!
'95 F-250 Powerstroke, 350,000 Miles, Mods: Phoenix chip, 140V IDM, Diamond Eye DP to 4" straight pipe, CCV mod, Amsoil synthetics throughout.
'04 F-350, XLT Lariat, Powerstroke, CC, Dually, SS exhaust, AirRaid intake and filter, Edge Evolution, PHP FICM programmer.
Old Mon, August 22nd, 2011, 07:04 PM
dietoremain dietoremain is offline
dietoremain is on a distinguished road
geez man thats a good one.. I sure hope hes ready for a rebuild cuz that motors DUSTED..
2002 7.3 F250 Supercab Shortbox
DIY intake
CCV dumped
Autometer gauges
WW/ATS 1.0 exhaust housing
Hutch/Harpoon in tank mods/hpX line
AIH delete/ebpv delete
TruCool trans cooler
Straight piped
PHP FU
