Old Thu, March 5th, 2009, 10:47 PM
Unless you are removing the unit from the vehicle or need to go to the dealer for some reason, you should never have to go back to stock. All you are accomplishing by doing that is quadrupling your programming times. You shouldn't have any problem switching between levels 1, 2, and 3 any time you like. If you are having problems, I need to be made aware of it so we can resolve it.
I'm going to jump in here because some of you might be confused by what Bill said (in bold). He's talking about removing the unit and sending in to him for work, or removing the unit and transferring it to another vehicle. In both cases, it needs to be returned to stock.
If, however, you enter a tune and then decide you just don't like the looks of the Gryphon in your truck (you're weird), or, you're concerned it might become "liberated" while being parked on some dark street at night (you're cautious), it's perfectly all right to leave the truck tuned to an advanced level and remove the Gryphon. Once the truck is tuned, the Gryphon is simply a monitor, nothing more. When you finally get around to reconnecting the Gryphon, it will show you at the tune level you left it at and everything will be fine.
Bill, I hope I didn't step on your toes here, just trying to prevent misunderstandings.
  #12
Old Thu, March 5th, 2009, 10:55 PM
No problem, Jack. I realize now that it could have been misconstrued. You covered it exactly. Thanks for catching that and saving another question.
  #13
Old Fri, March 6th, 2009, 07:27 PM
Shorse Shorse is offline
Shorse is on a distinguished road
no, i only went to stock so i could compare stock to level 2... There was a HUGE difference, so i went to go back to level 2 and it happened...
i dont go to stock unless i need to, like yesterday i had to take it out to go to the stealership... i will put it back in tomarrow ( Level 2), if all goes well, it was a one time fluke, no biggy... if it does it again, i'll post back...
thanks
2010 F150 XLT with the 3 valve 4.6 and 6 speed auto
