Old Mon, November 7th, 2011, 06:55 PM
God & Guns
Default Recon cab lights wiring
Got my cab lights in (Recon set that comes with the harness).The instructions is the copy of Motoman's instructions..which doesn't touch a whole lot on where the wiring goes. I'm gonna say the black wire is the ground, but where does the green wire splice into behind the kick panel?
Old Wed, November 9th, 2011, 09:10 AM
Recon Cab Light Install Question - Ford Powerstroke Diesel Forum
Old Wed, November 9th, 2011, 10:14 AM
God & Guns
"You should have a black wire and green wire running from the harness. I just grounded out the black wire on the sun visor bolts. The green wire I ran down the passenger side door. You take the kick panel off and there should be a black box sitting there with harness going into but nothing coming out. I just tested the little ports until one kit up when I turned the parking lights on. I cut the wire and spliced the green wire and the wire together and buttoned them up"
Exactly what I was looking for. Thanks!!
Old Wed, November 9th, 2011, 02:33 PM
Kewl!.....take care!
Old Wed, November 9th, 2011, 05:21 PM
God & Guns
Hahaha, yea I googled around. But never could find anyone that touched on the wiring part. Guess I didn't word it right. like the pic
Old Wed, November 9th, 2011, 08:05 PM
Use her next time.....she always seems to get it right.......Ouch!
Old Wed, November 9th, 2011, 08:25 PM
God & Guns
