Old Sat, February 18th, 2012, 06:54 PM
God & Guns
AutoEnginuity FAQ
Injector buzz test actuated the solenoids on top of the injectors. This can only be done with certain types of OBD2 equipment such as AutoEnginuity, Snap-On MODIS...my Aeroforce gauge can also run injector buzz and cylinder contribution test. The diagnostics tools like what you get at Autozone won't do these test.
Old Sun, February 19th, 2012, 06:08 PM
ToMang07's Avatar
ToMang07 ToMang07 is offline
That guy...
ToMang07 is on a distinguished road
Originally Posted by garyfink View Post
ok I did the siggy.
can you tell me what is a buzz test. I watched a video a while back on you tube from powerstokehelp.com and when they turned the key on the injectors sounded like they were sparking or buzzing. I can't here that on my truck.
F350 7.3l Diesel Buzz Test w/ Auto Enginuity - YouTube
02 F-350 Super Duty SCSB 4x4 SRW 7.3L TD, DIY-I, PHP-6 Phoenix, 4" Turbo-Back 409 MBRP, Glowshift 3 in 1, Fisher 8' MM2
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery."
Old Tue, February 28th, 2012, 11:43 AM
garyfink garyfink is offline
garyfink is on a distinguished road
my buddy has a top of line snap-on scanner will that do it?
E99 F350 , Magnaflow 4" Exhaust , AFE Stage 2 Cold Air, 3.73 Gears, Stock Tires , Transgo Tugger HD2 Repro. Kit with non-pwm apply valve , Landis Triple Disc Low Stall TC manual tc on/off switch, Deep Trans Pan, TS Chip waiting on PHP Tunes, TS Chip Burner.
Old Tue, February 28th, 2012, 09:05 PM
God & Guns
Not familiar with every model of snap-on scanners, but is say your chances are good. Look up what type he has and see what functions it has.
Old Thu, March 8th, 2012, 01:26 AM
BigAlsPSD BigAlsPSD is offline
Knowledge is power...
BigAlsPSD is on a distinguished road
At the main menu screen choose Functional tests, from there you will see the injector buzz test available.
Old Mon, March 12th, 2012, 02:18 AM
dietoremain dietoremain is offline
dietoremain is on a distinguished road
After alotta research we're going with the new stealth srp1.1 that just came out.. everyone loves them.
2002 7.3 F250 Supercab Shortbox
DIY intake
CCV dumped
Autometer gauges
WW/ATS 1.0 exhaust housing
Hutch/Harpoon in tank mods/hpX line
AIH delete/ebpv delete
TruCool trans cooler
Straight piped
PHP FU
