Old Tue, May 29th, 2012, 10:03 AM
Rheatherly's Avatar
Rheatherly Rheatherly is offline
Rheatherly is on a distinguished road
Keep me in the loop! My finger is on the trigger to order the it, I just don't want to spend $400 and it not be what I need.
2005 F350 6.0L 6 speed FX4
K&N CAI, Evolution CS
2000 Ford Explorer
1984 Bronco
351 windsor
To many to list
1968 Galaxie
Old Tue, May 29th, 2012, 11:25 PM
Enrique Enrique is offline
Enrique is on a distinguished road
You bet, will do. Heading out of town for work, should be back by sunday. If it arrived should have some results posted monday night. Its been at canadien customs since the 22 just got released today! I guess they wanted to make sure i wasnt going to terrorize the country with my php programmer
Old Wed, May 30th, 2012, 08:11 AM
Rheatherly's Avatar
I really hope it works like I think it will. Only remaining questions are fuel consumption, does it come with the monitor probe and can it turn off the CEL for the EGR delete.
2000 Ford Explorer
1984 Bronco
351 windsor
To many to list
1968 Galaxie
Old Wed, May 30th, 2012, 05:54 PM
Jeremy's Avatar
Jeremy Jeremy is offline
Spark Plug Inhibited
No egt probe, you have to buy that. And no on the CEL that is a PCM function. You have to get your PCM programed to ignore that CEL or get a regular tuner with custom tunes that removes the CEL for EGR delete.
I'm sorry, I didnt see that you had your EGR deleted.
19 F-350 6.7 Auto
16 F-350 6.7 Auto
Old Thu, May 31st, 2012, 07:09 AM
Rheatherly's Avatar
It's not deleted yet, I just ordered the delete kit. I may get it and if it throws a code I can plug the EGR back in and zip tie it out of the way. Would that stop the truck from throwing the code?
2000 Ford Explorer
1984 Bronco
351 windsor
To many to list
1968 Galaxie
Old Thu, May 31st, 2012, 08:30 AM
Jeremy's Avatar
Does your 05 have a MAF sensor? If it doesnt you may not have to worry about a CEL for EGR flow if you leave the EGR valve plugged in.
19 F-350 6.7 Auto
16 F-350 6.7 Auto
Old Thu, May 31st, 2012, 08:33 AM
Rheatherly's Avatar
I have no idea if it does or not. How can I tell?
2000 Ford Explorer
1984 Bronco
351 windsor
To many to list
1968 Galaxie
Old Fri, June 1st, 2012, 12:05 AM
Jeremy's Avatar
If you do, there is a sensor inbetween the air filter and and the turbo inlet. If you dont, you'll have the wires for the sensor and the plug that goes to it, but its plugged into a dummy plug instead of the maf sensor. About a 2" square sensor is visible if you have a MAF.
Old Fri, June 1st, 2012, 07:11 AM
Rheatherly's Avatar
If I do is there a work around for it? Either a dummy plug or leaving the EGR plugged in but moved out of the way?
2000 Ford Explorer
1984 Bronco
351 windsor
To many to list
1968 Galaxie
Old Fri, June 1st, 2012, 05:49 PM
Jeremy's Avatar
Sorry, i dont understand your question..
19 F-350 6.7 Auto
16 F-350 6.7 Auto
