Old Mon, July 9th, 2012, 02:29 PM
terrye terrye is offline
terrye is on a distinguished road
Default 65 Tow on PCM...Can I still get codes??
I have a 65 tow on my PCM from PHP.
I changed my fuel filter and put an new Glow Plug Relay on my truck and now it barely starts and barely runs like on 1 cylinder or something. check engine light.
I am trying to get someone with a AutoEnginuity.
Does the truck still show codes. Any ideas?
Terry
2003 7.3 6 speed. 65 tow and a bunch of little stuff.
Old Mon, July 9th, 2012, 03:40 PM
ticopowell's Avatar
Grown-up in training!
You should be able to get codes like normal, It shouldn't matter what tune is in the computer.
Old Mon, July 9th, 2012, 04:02 PM
God & Guns
Yep, I think the only codes they would block is the overboost code. Not all codes set off the CEL.
Old Mon, July 9th, 2012, 04:03 PM
God & Guns
I would go back over the installation of the GPR and fuel filter and make sure everything is sealed and connected right. Truck wont run on 1 cylinder.
Old Tue, July 10th, 2012, 01:10 AM
Default pulled the UVCH harness connectors>>>
and checked for resistance on glow plugs. Got resistance on all glowplugs. So UVCH harness under the valve covers are connected. Still have no clue.
Terry
Old Mon, July 16th, 2012, 11:19 AM
Default Fixed...
I installed the guts of the fuel filter backwards. Blocked the fuel to the injectors. MTNSAMMY came down from Big Bear and scanned my truck afterwards. a couple of minor codes, one for the air heater and one for the ICP that worried me a little, but the truck is running well.
Thanks,
Terry
