Old Wed, March 18th, 2009, 11:22 PM
kd4crs's Avatar
kd4crs kd4crs is offline
Not a Whopper
kd4crs is on a distinguished road
I don't see any reason why the painted PVC shouldn't work. Just be sure to use a paint intended for plastics and it should be fine.
Old Thu, March 19th, 2009, 07:51 AM
jimmyv13 jimmyv13 is offline
jimmyv13 is on a distinguished road
I know it will work...I just didn't want to have to mess with painting it.
Old Thu, March 19th, 2009, 09:29 AM
Look at it this way. Now you can pick any paint color you would like! Or maybe just black.
Old Thu, March 19th, 2009, 09:03 PM
kd4crs's Avatar
Not a Whopper
When I said it should work I was thinking in terms of the outer diameter. Anyway you should be fine. :o
Old Fri, March 20th, 2009, 09:46 AM
I might be confusing the two different types of pipe here. Is there a difference in the white and black pipes? When I went to Lowe's the DWV stuff they showed me was corrugated and flexible. They didn't know what I was talking about when I asked for a rigid DWV pipe, much like the white PVC, but in black.
Old Fri, March 20th, 2009, 11:01 AM
I don't know how well the corrugated pipe would work. What I've seen has fairly thin walls, and, if the outside diameter is right for the bellows, then it might have trouble fitting into the fender hole. However, it's not that expensive, and if it looks like it might work, I say give it a try. If it fits, it will work just fine.
The white PVC pipe is Sch 40, and has fairly thick walls. Dimensionally, it is identical to the black ABS pipe that I used.
There is little or no stress on this part of the intake. You can use just about anything that gives you the "tube" effect there.
Old Fri, March 20th, 2009, 11:32 AM
I didn't want to use the corregated stuff since it's not smooth inside and that may disrupt the air flow....and it doesn't look as good as the smooth sch 40 pipe.
Old Fri, March 20th, 2009, 11:43 AM
txarsoncop txarsoncop is offline
txarsoncop is on a distinguished road
There is "straight" sewer pipe that is schedule 20 PVC, usually used for septic systems. It's gonna half to 2/3s thinner than schedule 40 and much more flexible. It may be flexible enough to squeeze into the oblong shape in the inner fenders. If it couldn't be squeezed into fitting in the hole you wouldn't have enough material to shape it into fitting though.
Ya'll gotta keep in mind that these Lowes, Home Depot folks generally aren't "from the trade" so they might not be familiar with the products and/or what their intended purposes are.
FWIW, my local Lowes had the PVC test caps that AgentOrange used in his build. I used a 2" and a 1.5" test cap. Need to go back and get a 1" plug for the other hole.
I'll post a couple of pix when i get the plug but I've trimmed the rims off the caps & I'll do the same to the plug along with cutting it short so it doesn't project so far into the intake's air stream. Gives it a pretty clean look.
bill
the new guy
Last edited by txarsoncop; Fri, March 20th, 2009 at 11:41 PM. Reason: Plug size needed to be smaller...
Old Fri, March 20th, 2009, 12:10 PM
The guy at Lowe's told me to not screw with the intake on any vehicle "the manufacturer builds them like that for a specific reason"...after I told him what I was doing with it. I said, "Well, my reasons are different than Fords". He didn't offer much help.
Old Fri, March 20th, 2009, 12:19 PM
Oh yeah, I wouldn't tell them anything like that because you might end up with some hard core enviromentalist or something. I always leave it vague and tell them it's for a "project i'm doing..."
bill
Tags
dwv intake mod
