Old Fri, March 27th, 2009, 10:45 PM
jimmyv13 jimmyv13 is offline
jimmyv13 is on a distinguished road
A note from Corey in the pkg said the tune was loaded. BTW, I took a 159 mile trip today in tune 1 and got 17.1mpg @ 77mph.
Old Mon, March 30th, 2009, 10:43 AM
way2qk4u2c way2qk4u2c is offline
Ford F150 FX4
way2qk4u2c is on a distinguished road
Ok so after a week of riding around... it seems that my mpg is better than before. Its not hard to get 15 in the city now. I was usually around 13-14.
The only thing i notice is it seems like it takes forever to get into O/D like i have to really be going over 50mph (sometimes 55mph) and maintain that speed while messing with the pedal to push it into O/D
I havent tried level 2 yet to see if the same issue resides.
I would assume my custom tune is loaded already- since that is what was the delay in the upgrades.
2006 F-150 FX4 Dark Shadow Grey
Old Mon, March 30th, 2009, 12:12 PM
You can adjust the O/D shift points in the Custom Options, if you want. I've reduced the upshift and downshift speeds by the maximum amount (I think it's -5) and I get into O/D in the 40+ mph range if I'm not doing any kind of hard acceleration.
Of course, Bill may have adjusted your shift points for a more aggressive power curve from a standing start, and he knew I didn't want that.
Old Mon, March 30th, 2009, 12:18 PM
Ford F150 FX4
Very good info- i might reduce it alittle.
Old Mon, March 30th, 2009, 12:35 PM
Sure - it doesn't hurt to try. I reduced ALL my shift points and, all my TC lockup points by the maximum amount too. This only effects part throttle acceleration. It has no effect on WOT acceleration. I find that having the shift and TC lockups set the way I've done it, the truck seems to flow very nicely with other traffic, and I never try to beat anyone to the next light.
Old Tue, March 31st, 2009, 09:24 AM
Ford F150 FX4
Alright so i went into the programming and changed my 3-4 shift (std shifting) to -2 and it did nothing for me.
The O/D doesnt kick in until 55mph and above. Should i worry about this or leave it alone?
I drive alot of 40mph speed limits all the way to work and its not in O/D the whole way.
I didnt see any TC options to set in there?
Old Tue, March 31st, 2009, 10:23 AM
soutthpaw's Avatar
TIT (Tuner In Training)
I think you are gonna need Bill to tweak your custom tunes at this point if you could not get the tranny where you wanted it with the changes you made
Back after many years.
2003 F250 CC LB 4x4 7.3PSD
Minotaur user.
Old Tue, March 31st, 2009, 10:50 AM
I'm pretty sure you can reduce the 3-4 upshift and 4-3 downshift by -5. That's what I did. (I also changed the 1-2, 2-1 upshift/downshift to -2, the 2-3, 3-2 shifts to -3). Those are the maximum changes we can do.
I'm VERY puzzled that you don't have Torque Converter choices in your Custom Options menu. As I recall, in my unit, it's the next choice below the shift options? You and I have nearly identical Gryphon's (your's might be a little newer - mine is a converted Edge).
I think southpaw's right though, your custom tunes sound like they have the shift points way up in the rpm/speed curve (for more power) and I don't see how you're going to get the 3-4 upshift below 50. Bill CAN adjust those shift points down if it's really what you want. Even though I'm older than you, I don't really drive like a Grandpa. My truck accelerates easily with other traffic and I have no trouble accelerating faster if I want.
I just had a thought though. What's your gearing and tire size? It may be that you really don't want the O/D on much earlier than it is. (As I recall, when mine kicks in and the TC locks, the RPM is about 1100, and you probably would not want it much below that).
Old Tue, March 31st, 2009, 11:12 AM
soutthpaw's Avatar
1100RPM? that's pretty low for a gasser... how far into the throttle do you get before it unlocks. I would think the engine would lug pretty bad if you tried any acceleration with the rpm's that low on a locked TC
Minotaur user.
Old Tue, March 31st, 2009, 12:41 PM
Ford F150 FX4
Well i have the stock 20in rims from factory on my truck with stock tires.
Im not sure what that cooresponds to the gryphon becaus ei think i saw my tire size listed as 2760 i think- im not exactly sure by memory.
my gear ratio i dont know that either off the top of my head but i think i saw it in the gryphon set as 3:73
I have a edge converted to gryphon as well
Yeah around 50mph my rpms are at 1800 and once i hit 55mph i have to work at it to push it into O/D and then they go down to about 1200 rpm
Yeah i have no option for TC control at all
