Old Wed, April 1st, 2009, 12:43 AM
rsbeachbum2 rsbeachbum2 is offline
rsbeachbum2 is on a distinguished road
Default Putting edge in another truck
So the truck went away a couple months ago, and I'm just getting around to selling my edge now. It was one of the few that got tunes before a gryphon was required. My question is with these tunes, set for a CAI, work in another F-150 with my old intake in it, or would it need to be reset to normal, and then turned into a gryphon for him?
Old Wed, April 1st, 2009, 12:04 PM
If the other 150 has a different HEX code (and it probably does), then it's not going to work with the custom tunes. If the codes are the same and his truck is configured the same as yours was and it is the same MY and so on (in other words, a "clone"), then I don't see why it wouldn't work well.
If the only real match is the HEX code, then while it might function, the tunes are probably not right for his setup.
If the HEX codes don't match, you should be able to return your Edge to stock using Pegasus, since Bill tuned it. If not, since it's an Edge, using Fusion? Once the programmer is back to stock with canned tunes, it should recognize his truck if it's in the same MY group.
If he's installing your CAI, he'd want Bill to convert it to a Gryphon and tune for the CAI.
Old Fri, April 3rd, 2009, 09:28 AM
Yeah the guy wanting it doesn't want me to erase my tunes, but if I have to I have to.
I just wanna get this stuff out of my garage.
