Closed Thread
Old Fri, May 8th, 2009, 07:19 PM
Default Trouble Code Question
I recently put an older big head waste gate actuator on my turbo when I put in the wicked wheel. My buddy had it lying around. We tested it and it worked. When we installed it we preloaded it 1/8" or 3 turns. It definitely does not blow off like the stock one but you can hear it when you put your foot into it between 2 and 3rd gear.
Today after goofing around and putting it to the floor I got a check engine light. The code was P1249 Waste Gate Control Valve Performance. I asked a couple of buddies and they had never heard of it. Is this really bad or just a nusance code? Should I be worried? Any help would be greatly appreciated.
Thanks
Joe
2003 4x4 F350 Super Duty Crew Cab Short Bed
4" Down pipe and exhaust, Wicked Wheel, Modified Exhaust Turbo Housing, Big Head Waste Gate Actuator, PML Transmission Pan, Factory Tech Valve Body, Autometer Gage Pod, PHP FU2 Chip
Old Fri, May 8th, 2009, 09:58 PM
Joe,
It's more of a nuisance code. It's no big deal. It has to do with the PCM commanding wastegate operation but the boost still climbing.
The sound you are hearing during the 2-3 shift is turbo stall. It's not good for the turbo at all. There is a lot of boost in the intake tract when under load at high rpm. When the transmission shifts, the need for all of that boost is diminished slightly and the air has nowhere to go but back out of the turbocharger compressor. You will not hear a wastegate open.
Old Fri, May 8th, 2009, 10:56 PM
soutthpaw's Avatar
TIT (Tuner In Training)
Joe,
Cody, is that where the torque reduction map comes into play??
Back after many years.
2003 F250 CC LB 4x4 7.3PSD
Minotaur user.
Old Sat, May 9th, 2009, 09:27 AM
Nope. Unfortunately, there's not much one can do about it save for not driving the vehicle under those circumstances.
Any turbocharger will do it given the right operating conditions (like surge), but certain turbos will be more immune to it on certain engines.
It's caused when there is sufficient heat energy to maintain high boost/high compressor speeds and then instantly it's gone (during a shift or "throttle lift").
Old Sat, May 9th, 2009, 11:41 AM
Thanks for the info Cody. I will try to keep my foot out of it as much as possible, as hard as that is going to be.
Just for my own curiosity what kind of damage can that do to the turbo?
Old Sat, May 9th, 2009, 11:52 AM
NHRA6002 NHRA6002 is offline
NHRA6002 is on a distinguished road
On some engines depending on turbo, turbo stall on unloading can damage the compressor wheel.
05 6.0L CC DRW 4X4 Lariat FX4
4" t/b Magnaflow and Evo installed April 13/09
Old Sun, May 10th, 2009, 01:20 PM
ChuckD's Avatar
ChuckD ChuckD is offline
Duty, Honor, Country
Just put a blow off valve on there.
Chuck
1995 Mustang GT
2004 Explorer Limited
Closed Thread
