Old Sun, May 24th, 2009, 01:30 AM
Default I am impressed!!!!!!!!
Well if you haven't noticed the new picture in my sig that's what the gryphon did to my truck with the custom tunes. New paint job' bigger tires, lost two doors, and now have a blown 1100hp motor!!!!!
Old Sun, May 24th, 2009, 01:34 AM
Yah!, Big Foot rocks!
Old Sun, May 24th, 2009, 01:43 AM
Ok, So after getting the gryphon loaded with the tunes on Friday and having to work the rest of the day. Worst case senario happened. The sky opened up and it rained for a good 4 hours. I thought "no way!" but it came down anyway.
Old Sun, May 24th, 2009, 08:07 AM
My first test run was to the grocery store. I did not go to the local one I went to the grocery store a little further away in Sioux falls. Had the butterflies in my stomach ever since I loaded the tunes. Well me and the little girl were off to the store, she had to try out her new booster seat.
PID'S I had on:
Cht
Speed
Volts
Comm gear
Just my luck! We get to follow slowa$$ Sunday drivers out to the interstate. I did feel something though. Eventhough they were driving slow, why did it seem I was going fast? Wierd? Turned the gps on and confirmed the feeling. Needle was at a +5 of the gps under 40 mph and +8 overthat. Got the grocery list out and wrote #1 adjustment tire size. The big test was my favorite double left hand turn to get on the interstate. Yes I was first up on the inside lane. Waiting patiently for the stop light to turn green. Told the little girl "hold on!".
Then it happened the light turned green and we were off! I was being cautious but yet aggresive due to the wet concrete. Went into the corner doing a power slide drift. Hung on to it and maintained it 3/4 of the way up the ramp. By the time I hit the entrance I was doing about 85mph with about my foot into it only a 1/4 to 1/3 of a peddle. My little girl kept repeating "again dad!" I said "that once was enough". Other than that little bit of fun I found the tune quite enjoyable. With new found passing power, I am happy so far.
One concern their is a little tc lock hiccup. It happens when I was going 40-45 in forth. Let the foot out of it slow up a few and ease back into it, the tc acts confused. It's like you nudged it and all of the sudden it woke quickly not gradually.
Redid ts to 2480 that works out to 6.3% squish
2470=7%
2498=5%
Weird the ph was at 2465?!
The other thing I noticed is the cht running 1-2 degrees warmer? At 80 mph at 71 degrees cht was at 209-210.
I love the shifts. I did not play with the firmness. Why do you have to?
With the ud pulleys I know the idle needs a bump she's running at 12.8 when at a stop in d with alot on.
Old Sun, May 24th, 2009, 11:05 AM
Glad you're having fun Lars! Seeing 12.8 volts at idle says, "Raise the idle speed" to me too. I'd try as little as possible though, maybe 50 RPMs and see what happens?
That's a big speed error though. If I understood you correctly, the truck said it was going 8 mph faster than you were really going at interstate speeds? That's a 10% error! And, that doesn't seem right for a custom, unmodified tune. I wonder if your gears are correct? I'd check both GR and TS and plug in the values you used to use with your canned tunes.
You might want to play a bit with the TC lock/unlock in the 3-4 shift range. It sounds like the TC is too sensitive, which is what I felt. I simply reduced both the lock and unlock points and I like the result a lot better. Tins is clearly something Bill could also adjust, but it almost has to be done by trial and error and "feel" on the actual truck doesn't it? Possibly, once you get the part throttle shifts and TC behavior to your liking, you could tell Bill your "custom settings" and he could adjust your tune. If I ever feel Bill has time for this sort of "fine tuning", I'll let him know how I've set mine up. Right now, he has more important things to do.
I agree, no point in messing with the shift firmness at all. I think it's perfect in my truck.
I doubt the CHT difference is a big deal. Possibly caused by a different A/F ratio? And, that's clearly in the range it needs to be for efficient operation.
Old Sun, May 24th, 2009, 03:37 PM
The CHT has to do with both the adjustments to AFR and the adjustments to the timing curve. Both will raise CHT slightly but, as Jack said, it's not anything to be concerned about.
The T/C lockup in 4th is a relatively simple fix. I just don't get why some trucks do it and some don't. Anyway, we just need to change the tip-in lockup delay and lock points to correct that.
Glad you're enjoying the ride. I do have to give you a little crap for goofing around with a youngster in the truck, but it sounds like she's at least having a good time. Besides, I can't say I never did that myself.
Get with me next week and we'll tweak out the rest of the stuff for you.
Take care and have a great weekend!
Old Sun, May 24th, 2009, 11:50 PM
Thanx Bill for the response and Jack also.
Glad to know the relative meaning behind the raised cht.
I don't know if Bill or Jack have ever done much motorcycle riding?
But this is my comparison.
Hop on a street bike with just the basics and it seems like you fighting for every little inch of riding when going down the road. This is what I felt before the custom tunes.
Now hop on a touring style bike especially a goldwing. Before you know it you are going 85. With out looking at the speedo now you are at 105. Then you look down and say time to back off. This what the truck feels like now with the custom tune. More freed up and alot less digging/fighting.
Yah shouldn't had her in the truck and pulling that stunt no excuses!
But I was relying on the truck to hook up better than that and I should've peddled out of it.
I'm going to bump the idle up 50-75 rpms tomorrow.
Thanx guys
Old Thu, May 28th, 2009, 02:48 PM
dnkrm dnkrm is offline
dnkrm is on a distinguished road
Lars- I am having a similar issue with the TC. Mine seems to be anywhere from 45-80. I will go to pass someone and it will kick down just right and the power is awesome! But the next shift seems clunky for lack of a better word and once in a while I will have the same feeling like the TC is confused and it will jump in and out. Hopefully Bill can hook me up with the same fix! thanks
Old Thu, May 28th, 2009, 05:26 PM
SubiGT's Avatar
SubiGT SubiGT is offline
Location: 2nd star to the right, straight on 'til morning(Ohio)
SubiGT is on a distinguished road
I get a little tq converter hiccup too. It happened before and after Gryphon, steady state cruise, 45-70mph. Maybe I'll PM Bill about it and he can incorporate it into my custom tune.
current off road toy
  #10
Old Thu, May 28th, 2009, 06:17 PM
average-joe average-joe is offline
Sex alleviates tension
average-joe is on a distinguished road
I noticed a volt drop off from 14.6v to now 13.8v it all works well so it can't anything to worry about.
Quality means doing it right when no one is looking.
