Go Back   Power Hungry Performance Forum > Power Hungry Performance Product Information > 6.0L PSD FICM Reprogramming
Power Hungry Performance revolutionized the 6.0L FICM (Fuel Injection Control Module) programming and has been the industry standard for FICM modification for almost 15 years.
If you have questions or would like more information about the benefits, please post here.
Old Mon, June 4th, 2012, 05:53 PM
Fl Mach 1 Fl Mach 1 is offline
Fl Mach 1 is on a distinguished road
Default FICM progamming suggestions
Hey all,
It appears that my FICM may be on the way out so I am looking at having it repaired and programmed at the same time.
Right now I am looking for some guidance on what FICM program to choose. So here is a little background on the truck
Its is a 2003 f350 CC 4x4 LB that is used primarily for daily driving and for going on vacations. I tow with it occasionally but nothing north of 7500lbs.
Right now the truck is nearly stock, the only major mod is an EGR delete. It still has the stock headbolts, hence my looking for guidance since I really don't want to have to do studs right now. I have an Edge Insight CS with EGT and fuel pressure sensor to keep an eye on everything. I recently changed out the oil cooler, did the EGR delete and swapped over to ELC coolant.
In my research I also found that the current ECM calibration is not the most desirable, its VXAP2N2 and the TCM is TQAUON5, so I am also looking at doing an ECM rollback for the EGR delete. I was wondering if it would be worth it to also have the ECM tuned as well.
Any and all suggestions are greatly appreciated
Thanks
