Delivery ???
If I was to order today, how fast can you ship me a Grypon ? The reason I ask is because I am in the process of ordering parts for my differential re-gear and I need to calibrate the speedo to accept the new gear change !
I will be going from a 355 to a 410, not that you needed to know that but in forums like this people usually ask. |
From my limited knowledge, is that you don't need to calibrate the speedo for a gear change.
Thanks for the input and by all means I'm not trying to be a smart @#$, so maybe I should have said that I needed it to reprogram the PC to accpet the new parameters of the re-gearing or up sizing from a 355 to a 410.
I believe that the speedometer in in my 01' F150 is calculated by sensor and wire instead of the traditional gear and cable. |
| All times are GMT -4. The time now is 04:12 PM. |
