Wed, November 4th, 2009, 12:41 AM
Originally Posted by cleatus12r
Bamboo,
Bill usually writes programs that feel fairly "stockish" down low.
Have you tried adjusting the idle validation switch detent?
Try this.....
Push the accelerator pedal down very slightly and slowly with your hand until you hear an audible click. (BTW, this only works for old body style trucks). If you have to push the pedal down more than 1/8" or so before you hear the click, you need to "adjust" the switch detent plate. This immensely helps the drivability of the '95 to '97 trucks.....especially while "chipped".
Where is this switch detent plate located?
