Originally Posted by Power Hungry
It'd be nice if there was a way to forego the 1st gear and just start out in 2nd. Then you can switch to 1st gear starts when you are loaded down and need it. See? They should have asked me what I thought.
instead of putting into drive you can start out in 2nd gear then once you get going go to third..then drive.
that might work
One question one of my friends asked me to tow there truck from lexington to ashland, KY which is about 85-100 miles. the last 20 i would say is uphill should i use my Tow tune. If he still has the same truck its just a mid size truck about the size of a ranger maybe a little bigger(GMC). be sure to rub it in that if he had a real truck(ford) it wouldnt need to be towed.
40 series Flowmasters, K@N CAI, Jet MAF, Troyer Under Drive Pulleys, Stainless Works Longtube headers/Hi Flow CATS w/X-pipe, Ram Air Hood G-Force, SCT X3 programmer with custom tunes
