well havent used the 100per yet its been stuck in 120 so far  ill try it out tomorrow and let you know. I did get to use the 40 tow I was at 19,600 gross. it pulls very nice revs kinda high i think.. 3K before it shifts not sure if thats normal.. but the 40 hp with that load helped alot im very happy! i had to pull a big hill and it started surging bad then the truck down sifted and it went away. On the flat parts it ran 70mph at 2000 rpm  Ill keep updating..
02 f-250 supercab 4x4 . Pyro,boost,trans temp guages,6637 intake 4 inch exhaust, 40t,65t,80dd,100p,120R and J/W valve body.
