Thread: Edge-vs-Phoenix
Old Wed, September 5th, 2012, 08:14 PM
The Juice module IS NOT a programmer OR a chip. There is proper nomenclature for each. The Phoenix is a "chip". The Juice is an inline module. The Edge Evolution is a flash programmer.
The Juice will work with the Phoenix regardless of whether or not either is in a "stock" setting or otherwise. However, you WILL run into P1211 codes if you push the truck in any setting other than "stock" along with the chip in an aggressive power level. The tuning of the chip already increases injection pressure (which is ALL the Juice does anyway) along with a slew of other things. Use the Attitude to watch EGT and leave it in stock or level 1.
