Old Fri, April 10th, 2009, 03:45 PM
soutthpaw's Avatar
TIT (Tuner In Training)
Talked with Bill last night and he is going to use the 2001 EBM1 DPC-452 VRAA6 base files as he says it has better shifting than the EBM2 or 3 files... Only thing I will need to do is disable the PATS functions... which is fine with me cuz I hate the damn thing..... Only have one matching key anyway which is ziptied to the ign column But he is gonna do that on an initial set of canned tunes so it makes my initial setup and install as easy as possible :thanks: Bill
I guess the EBM 1 2 3 are similar to the PMT 1 2 3's used in the trucks? If I remember the PMT1 is the preferred PCM due to shifting quality right? I would think the shift patterns on the Excursions are different from the F250s due to the max CGVW and that u cannot gooseneck or 5wheel an Excursion. They probably are a bit softer for that SUV effect too
ASE Master Auto Technician
2001 Ford Excursion 7.3 4x4
