Old Tue, May 26th, 2009, 03:41 AM
The next rebuild of Pegasus no longer uses FTP so router problems should be over with. The MSCOMM32 issue was related to the installer.
Outside of that, we've had very few issues with Vista, well... except for Vista 64. I've got a fix for some of the COM port problems where you are now able to specify the desired COM port and bypass the auto-detect. I also fixed the UAC issue with the COM port.
Vista still has other problems in relation to the self-update mechanisms. Several folks have complained that the self update doesn't work. I'm trying to work around that and for now all we have to do is manually run the Update.exe file found in the Pegasus folder. (C:Program FilesPHPPegasusUpdate.exe)
There are a few other goodies added, but I'll need to get them documented and tested first.
