Old Thu, August 26th, 2010, 12:49 PM
tiny's Avatar
tiny tiny is offline
Trying to get by
Location: The wind-farms U.S.A. (Heyburn, Idaho is home)
tiny is on a distinguished road
Help HELP!!!! I am getting injector module codes
I am getting a P1316 injector driver module codes detected code and in the morning, or really if it's been shut off for several hours, this truck runs like it's missing on several hits. It will also not reset code. This happens until my truck gets up to FULL operating temp, then check engine light goes out and code can be reset. I really need my truck so if I can get help fixing it before I wind up in a dead truck on the highway that would be nice. If anyone has Any advice it would be great. Thanks everyone. BTW it's my 2003 f250 with 7.3L got gryphon w/canned tunes. Thanks again.
HOW CAN I BE LOST, I GOT NO WHERE TO BE?
IT AIN'T NO RAG, IT'S MY FLAG!
Old Thu, September 9th, 2010, 08:31 AM
tiny's Avatar
Trying to get by
Help Getting worse
This issue is now getting to the point that it is fairly constant. The hitting happens mostly at idle but every so often it "jumps" while going down the highway. I have replaced fuel filter and added both a full shot injector cleaner as well as added to fuel. My work hours ate longer then the local shop's so I need to fix this myself if I can. Thanks
Old Thu, September 9th, 2010, 11:20 AM
If you cant do a buzz test and figure out which valve cover harness is your issue you will have to pull the covers and take a look at the connectors. They have issues coming un-clipped, and Ford sells a devise that helps keep them together.
Old Thu, September 9th, 2010, 02:19 PM
DND58 DND58 is offline
DND58
DND58 is on a distinguished road
Tiny, on the inboard side of each valve cover, you can see a wire harness connected to the valve cover. You can disconnect this harness, and use an ohm meter to see if you may have trouble under the valve cover.
Test on the pins going into the valve cover to read resistance from the glow plugs and injectors. Getting good contact of the test leads to the pins can be a pain.
G G I I C I I G G
Test between "I" and "C" to test the injectors, should be less than 5.0 Ohms.
Test between "G" and battery ground to test glow plugs. Should be between 0.6 and 2.0 Ohms.
Dean
Dean
2002/F-350
Old Thu, September 9th, 2010, 02:50 PM
Thats about the best way to check!
But beware, if the connection problem is intermittent the the test results can be misleading and a visual inspection will be necessary.
Good Luck.
Old Thu, September 9th, 2010, 02:58 PM
tiny's Avatar
Trying to get by
Default Thanks guys
Thanks I will check that when I get home tonight and hopefully get some results. Will let you know
