1997 to 2003 F-150
Old Sun, April 4th, 2010, 12:02 PM
texas offroading
Default bad cats?
ok so im still chasing the p1151 code. im starting to think its one of my cats clogged up or gng bad. ive noticed a rattle from the front drivers side getting louder and louder and occurring more often. so my questions are:
can a bad cat. cause a p1151...which is lean or rich in bank 1 sensor 2
and secondly are there catalytic converter insulators or heat shields on my truck?
i will most likely goto high flow cats....but what abt the pre-cats???
1999 f150 4x4 - Flowmaster 40 series exhaust - 33" BFG M/T km2's - PHP Gryphon Programmer - RotorPros Slotted rotors - Mag-Hytec Diff Cvr
Let's go Wheelin!!!
Old Sun, April 4th, 2010, 01:47 PM
P1151 is basically a lean code for Bank 2 Sensor 1.
Have you changes that sensor yet?
A quick and easy way to verify it is the sensor is to switch it out with the O2 on Bank1. If the issue now is on Bank 1 then BINGO!
If problem continues on the Bank 2 side then I would be looking elsewhere.
Do you have a way of monitoring the O2 sensors?
Old Sun, April 4th, 2010, 11:57 PM
Do what Dave suggested with switching them.
The HF cats will replace both the precat and cat.
Old Tue, April 6th, 2010, 06:53 PM
texas offroading
thankx for the recommendation dave...ive nvr messed w 02's b4 so its looks like its time to learn. interestingly, i got p1153 yesterday and the gryphon gave me a description something like 02 slow to switch or something....i cleared it cause i was at a gas station. but it seems more and more like an 02 is gng....ill try switching them and see what happens...
just so i know where does each end of the o2 connect?...i can see the one end around the back of the headers but where does the other end connect?
Let's go Wheelin!!!
Old Tue, April 6th, 2010, 08:06 PM
They will connect to the main harness above/ around the transmission.
If you don't already have one, now would be a good time to get a O2 sensor socket. They are fairly inexpensive but will make life a whole lot easier.
Old Wed, April 7th, 2010, 02:59 PM
texas offroading
ah ok, what does this sensor socket do? im guessing its a testing tool that tests voltage?
where can i get one... autozone, rockauto.com???
Let's go Wheelin!!!
