Old Sun, January 23rd, 2011, 12:28 AM
morfn321 morfn321 is offline
morfn321 is on a distinguished road
Default Tire size in the gryphon
Can anyone tell me what size in mm I should input. I run a 275/70/18 in the winter and a 35/12.50/20 in the summer. I tried the formula from edge but spedo is still 4mph high. Thanks greg
Old Sun, January 23rd, 2011, 09:30 AM
Greg, when you have the Tire Size entered correctly, the dash speedo will read about 2 mph higher than a GPS at 70 mph, due to mechanical errors. However, the odometer will read correctly. My guess is, you are not adjusting for "squish" - the flattening effect of weight on the tires that reduces the effective size.
The Edge formula does not account for squish, the Gryphon formula does. Try multiplying the TS you used by 0.97 and adjust from there if needed. If the speedo still reads too fast, reduce the TS more. If too slow, increase the TS.
Old Fri, January 28th, 2011, 08:11 AM
Jim Allen Jim Allen is offline
Jim Allen is on a distinguished road
Why not measure and enter the exact loaded circumference and set it to the MM?
I could swear this was in the Edge instros:
1) Set the truck on a flat, fairly smooth concrete surface with a little room to roll. Make sure tire pressure is set to your correct or chosen pressure.
2) Use a large carpenter's square to find wheel centerline of one rear wheel and then mark both the tire and the ground in line with the wheel center and perpendicular with the ground with a magic marker.
3) Roll the truck forward exactly one tire revolution and then use the square again to line up the mark on the tire with the centerline of the wheel and then mark the ground opposite the tire mark.
4) Measure the distance between the marks on the ground and you have the circumference.
This method accounts for tire pressure, tire wear, vehicle load, even temperature if you want to be that pedantic. It will change a few MM with tire pressure and treadwear, I know because I've checked. If you did it with a very hot vs a very cold tire, you could account for that as well.We are talking differences in a few MM. I found a difference of about 15mm between two identical size (but different brand) of tires
FWIW, I find GPS speed readings inconsistent if you are looking for perfection. I use them for spot checks mainly
Old Fri, January 28th, 2011, 09:42 AM
If you use this method I would do three revolutions and divide the final length by 3. Helps to increase your accuracy. I would never completely trust just one of any sample.
If you use a GPS, do not use the speed function, like Jim Allen noted, there are inconsistencies while moving. Use the odometer of the GPS and the odometer of your truck to get them aligned.
Old Sun, January 30th, 2011, 12:01 PM
Dark Rider Dark Rider is offline
Dark Rider is on a distinguished road
can I adjust the tire size while im driveing to get the correct speed or do i have to stop and turn off my truck every time?
Old Sun, January 30th, 2011, 12:07 PM
You have to stop to reprogram the truck so yes.
