2008 Screw 5.4 went from tire size 275/65R18 to LT315/70R17. I first used the formula in the owners manual to calculate the correct number and by doing this I got 2741 so i programed this in took a 25 mile drive to the parents and used two higher end gps to verify speed and basically i had to show 75 with the speedo needle to go 70 according to both gps. at my parents i did another calculation this time taking the overall diameter of 34.7 and multipling it by 25.4 to get 881x3.1415 and got 2769 and then programed that new number and the speedo was still off by 5 according to both gps
Am i not doing something right or is the programmer not making the correct modifications to the cpu. any help would be great |
When you change your TS you must also check your GR. When you open up CO on the gryphon it puts in place holder values. Follow Jack's Q&A in the gryphon programmers section it's pretty good and straight forward.
Right now all i am running is the canned tune on tow so I can get better shifts and update my tire size until my custom tunes are done so I dont know if this makes a difference or not to your response but I will be sure to check that out and make sure its right. Thanks for the info I apperciate it
You're not accounting for "squish". Try subtracting 3% of 2741 to get a more reasonable "loaded" circumference. When I do this, I get a value of 2741 - 82 = 2659 mm.
Unless you compensate for squish, your PCM will think each revolution of your wheels moves further than you are actually traveling. That equates to to a higher speed than you are actually doing. Try it with 2659. If you're still indicating faster than you're actually moving, reduce it still more. Oh, and Lars was correct too. Make sure your Gear Ratio value is correct when you do this. - Jack
To add to that, don't use the speedometer to gauge if you have the right tire size or you will be chasing numbers all over ther place; you should be comparing odometer to your GPS' trip mileage counter. There are different ways you can make it work or you, but you will find it is much more accurate and easier to know if you need to go up or down on tire circumference. If my GPS is clicking off tenths faster than my truck odo, I need to raise my tire size...if my truck odo is ticking out faster than the GPS, I lower the number. So far on Toyo MT 35x12.50-20's at 43 psi I found that 2702 is about as close as I'm going to get.
Call Procomp and ask. Every tire manufacturer should be able to tell you what pressure to run for the aplication, even loaded or unloaded. For example, on my 06 Screw with 35" Toyo M/Ts, I was told by their customer service to start with 45 psi, and adjust accordingly by gauging tread wear. I now run them 43 psi front and rear. If I have a 6000lb trailer on the back (600 lb tongue weight), I have to pump up the rears to 65 psi. They should be able to tell you all that info at Procomp's customer service line.
Just as a "guess", I suspect 35 psi is way too low. The OEM tires I had on my truck were recommended to be at 40 psi. At the recommended pressure, you maximize load carrying ability and treadwear, and minimize rolling resistance, heating (due to sidewall flexing) and hydroplaning on wet roads. If you over inflate, you tend to wear out the center of the tire tread and you increase stress on the entire tire and wheel which can lead to blowout. I think, at the correct pressure, the squish value I gave you will be just about right. I was actually coming up with a 6% correction given your speeds, and that tells me you are underinflated too. - Jack |
One thing to keep in mind is that the gear ratio calculator is not always 100% accurate. It is a best guess as to diameter based on the tire size designation. Tires with the same designation can actually vary quite a bit when measured and I've seen differences as much as 5% between different tires of the same "size". Even tires listed as 35" can vary +/- ½".
The first place to look is the tire manufacturer's website and see if they list a "rev per mile" value. If they do, take this value and divide it into 1609344 (ie. 1609344/rev per mile). This will give you the tire size in mm. The next best thing is to park the truck on a long, flat surface. Mark the ground and the tire where it touches the ground. Roll the tire forward (or backward) 3 rotations and mark the ground again. Measure the distance and divide by 3. This gives a really accurate tire size value. If using inches, remember to convert to mm by multiplying by 25.4. Hope this helps.
