Old Thu, July 30th, 2009, 10:02 PM
Shorse Shorse is offline
Shorse is on a distinguished road
do i need custom tunes after muffler change
I am really tight on money right now, but after i installed my magnaflow 14" muffler today, it smells like i am running really rich. I'm not sure if it's because i am looking for it now or not, but it is STRONG smelling. I have 275-55-17's, and a little extra weight in my truck tool box( ~200 lbs). Other then that i am stock. I usually run level 2 with the gears and tire sizes adjusted.
If i get a custom tune, i am torn between a 87 fuel saving tune, or a 87 performance tune. My gas millege sucks, 12-14 mpg mostly highway, and if that can be improved with a tune and not effect my perfomance too much, then i'll go with that.
I live in a hilly place out in the country, and rarely go into the city... but i tow my boat every other week (4000 lbs), and a quad on a heavy trailer every once and a while (2000 lbs)... so i need to tow on this same tune also...
what do you guys recommend i do, and can the muffler make a difference at all?
2010 F150 XLT with the 3 valve 4.6 and 6 speed auto
Old Thu, July 30th, 2009, 11:27 PM
There will be a lot of help here shortly. I'm no Gryphon expert so hang tight!
Old Fri, July 31st, 2009, 10:36 AM
white eagle white eagle is offline
white eagle is on a distinguished road
I think the muffler will only effect how you feel about your truck I really don't think it needs a special tune
you may be smelling you muffler burning out should get louder tooo
Old Fri, July 31st, 2009, 10:47 AM
I doubt the muffler will make any difference to your tune at all. Towing weights of 2000-4000 tells me a custom tow tune would be worthwhile, optimized for the 4000# load. The 2000# load could be towed with either the tow tune or a standard performance/economy tune.
I do think Bill can write tunes that can both save you on gas and still perform well. He did that for me.
Old Fri, July 31st, 2009, 02:46 PM
Jon82387 Jon82387 is offline
Jon82387 is on a distinguished road
The smell is probably just the new muffler burning off some of the oil that is on it from being new i had a smell after installing my flowmaster kit it will prolly go away after a week or so.
Old Fri, July 31st, 2009, 09:15 PM
i did not know mufflers had to break in... good to know.
so he can make me a tune aimed at fuel savings and performance, what form do i fill out?
