Old Tue, January 26th, 2010, 02:37 PM
Diesel Rookie Diesel Rookie is offline
Diesel Rookie is on a distinguished road
Question Vegi Stroke
Just out of curriosity does anyone have any experience with the Vegi Stroke setup on one of these trucks. I have been reading about it on the interenet and it looks very interesting but would like to hear from someone who has some expereience with it.
Would Bill need to write different tunes for this or would it work with the ones I have?
Just currious.
Thanks
Joe
2003 4x4 F350 Super Duty Crew Cab Short Bed
4" Down pipe and exhaust, Wicked Wheel, Modified Exhaust Turbo Housing, Big Head Waste Gate Actuator, PML Transmission Pan, Factory Tech Valve Body, Autometer Gage Pod, PHP FU2 Chip
Old Tue, January 26th, 2010, 11:41 PM
F-127's Avatar
F-127 F-127 is offline
Tuner novice
I haven't converted a Powerstroke, but I can tell you some things about some work I did this past summer converting a New Holland tractor to a two-tank vegetable oil. This tractor was a 6.7 Iveco common-rail. Not a HEUI, but it was similar in being electronically controlled. There was no modification in tuning, but max power was decreased about 80% due to the less energy in VO compared to diesel. You should not need programing, but granted there might be slight and I'm guessing very slight variations being a Ford ECM takes shift points, etc. into consideration based off of throttle position(being you need 25% more fuel to achieve same output). If you want power to return to where you currently are, you could do it with programing, as long as you aren't maxing out the injectors already.
Thomas H.
Old Wed, January 27th, 2010, 02:21 PM
Thanks for the info. Do you feel it was worth the work? Have you seen any cost return? With the 20% loss in power you saw was the tractor still able to do what is was supposed to do?
Thanks
Joe
Old Thu, January 28th, 2010, 03:34 PM
F-127's Avatar
Tuner novice
I guess it mostly depends on the situation. If you have a readily available, low cost waste oil you can get and all you need to do is filter it, I can see you being able to cash flow it somewhat easily. However if you need to purchase a screw press or other large investment, its going to take longer. I worked on this as a research project and we were able to 'use' a screw press at no cost from a local cooperative, and the local county highway department used the fuel at no cost(we needed to find a operator who was willing to participate). In the situation, the tractor mowed road ditches and did not have any problems with lacking horsepower. I would say its not short term payback, but definitely long term. Although I haven't really taken into consideration labor costs, which most people don't care because if they are doing this they probably have a general opinion of "screw foreign oil" and are going to do whatever it takes.
Thomas H.
Old Mon, March 1st, 2010, 11:41 AM
Cory S Cory S is offline
Cory S is on a distinguished road
i have ia v3 vegistroke system and a v2 vegistroke system. waiting for the v3 system to come in for my truck which will be my 3rd install what questions do you have. i have noticed the motor runs considerably quiter but no loss of power on stock programming if there is a loss of power it is very small. what queations do you have?
2000 Powerstroke (PMT1)
4x4 auto XCSB
Old Thu, March 4th, 2010, 11:28 AM
muns53's Avatar
muns53 muns53 is offline
PHP Tuned and Vegistroked
I've been running a V3 on my '02 7.3L Excursion for about almost a year now (20K-ish miles) and I love it. It's really more about whether or not you want to be a oil-burner. It takes some effort in the beginning to figure out collecting and filtering, but I don't find it difficult at all any more.
I collect in cubies from three restaurants, then I use a settling system with a WVO Designs centrifuge to clean the oil. Then, it's just pump from my 275-gallon clean oil storage tote into my 40-gallon undercarriage tank and away we go. The Vegistroke I have is fully automatic, so my wife isn't really intimidated by it at all - which I really like. I know they sell less-automated versions as well. (Dino Fuel Alternatives | Alternative Fuel, Vegetable Oil Fuel Systems, Vegistroke & Bio Diesel)
I got the PHP Gryphon and am running Bill's 80HP Performance veggie tune that he customized for me to burn Veggie about 99% of the time. I also have a 65HP Tow veggie tune and a regular 80HP Performance diesel tune loaded in there at the moment. For me, it was worth a few extra bucks to get a veggie-specific tune. It is not drastically different than the regular diesel tune, but enough that it matters to me. FWIW, I taught my wife how to use the Gryphon, too, and she has no problem with it either.
I don't notice any power loss between vegi and D2, but I believe there is some small amount - like 5% range. There are a few people who have documented this with Powerstroke motors on actual dyno runs. Also, I get 1-2 mpg less mileage on vegi. I have been averaging in the 16-18 mpg range... but I like throwing the Ex around a bit. Highway mileage is much better.
I took a 4300 mile cross-country trip shortly after my install and only burned about 15 gallons of diesel the whole way - the rest was all veggie oil. I am taking a 2500 mile trip around Easter and hope to achieve the same results.
PM me if you have any other questions you want to ask.
