Old Thu, February 12th, 2009, 10:33 PM
04FX4 04FX4 is offline
Default Question about exhaust.
I want to up grade my exhaust. I do not want to loose any hp or tq.I am leaning towards magniflow but what is better. SI/SO or SI/DO? I see bill always saying SI/DO so which one is best?
Old Fri, February 13th, 2009, 10:42 AM
From my experience, either single in type is fine. The exit is personal preference as to whether you want a single pipe out the passenger side or duals out the back/corners/sides.
Anyone else have any thoughts?
Old Fri, February 13th, 2009, 10:57 AM
Back in the bad old days, before most of you were born, duals with straight pipes that were tuned properly (you didn't want interfering pressure pulses) were supposed to "scavenge" the cylinders better during the exhaust stroke so that they were "cleaner" for the next intake charge.
I imagine, with the introduction of catalytic converters, EGR valves and the like, that these ideas sort of went the way of the dodo.
You'd need a bigger capacity exhaust system if say, you put a blower on the engine (conservation of mass again), but I doubt there's too much reason for changing it otherwise (beyond looks or sound). Possibly you can get a slight power increase with a less restrictive exhaust system, but I doubt it is going to be a significant change on anything beyond your wallet. My
Old Fri, February 13th, 2009, 03:15 PM
I changed the exhaust on my '73 2wd about a year ago. It's had a few different setups since I started modifying it about 14 years ago.
The one I have now is the one that's staying until it gets turbocharged.
I picked up so much more midrange and top end (as if 4000 RPM is high) that it was scary for the little bit I actually did to it. (dyno proven)
My recipe for success:
Single exhaust. Sure it sounds terrible but it works. The headers never changed....neither did the first 6 feet of 3" dual pipes or the dual dynomax welded mufflers. However, immediately after the mufflers, I joined the two pipes with a "y" (not a "Y") and ran a single 3" pipe out behind the left rear with very little arch over the rear axle.
Instead of losing torque at 3000 RPM, it held absolutely rock steady up until 4000 RPM. For reference, the dyno graph for torque hit 353 ft. lbs. at 1800 RPM and stayed perfectly flat until 3500 RPM. The old setup began dropping torque at about 2600 RPM....even though it SHOULD have had better breathing.
I'm a firm believer in smooth exhaust flow....I've seen it help so many vehicles. For example, a friend's 66 Chevelle with a worn out 327 (45% leakage past the rings on most cylinders) with long tube headers, dual 2.25" pipes and glasspacks dumping in front of the front axle was a complete turd at all RPMs...it was terribly doggy.
Then (against advice from EVERY exhaust shop) he installed 3" pipe from the collectors into *cough* Flowmasters *cough* and did side exits in front of the rear tires. Did he lose any power? No. From idle all the way to redline (nearly 6500 RPM most times) he gained. It sounded terrible due to the Flowmasters, but it ran like a mad chief after the exhaust job.
You DO NOT want backpressure at all. It's a myth. If backpressure was good, stuffing a potato in the tailpipe would make your front wheel drive car do wheelies. You don't want stagnant flow either. Once the flow slows down too much, the engine has to work to push the exhaust out of the pipe.
Old Fri, February 13th, 2009, 04:08 PM
kokopellimotorsports's Avatar
addicted
Cleatus, this is why I am upgrading my exhaust. I will be putting on high flow cats (magnaflow) to a si/do corner exit MBRP exhaust.
To the OP, when you are ready for exhaust let me know, I have access to many manufacturers.
Ty
2001 Dodge Cummins
Tuning is addicting. Lol.
Old Fri, February 13th, 2009, 04:38 PM
Nice post, Cody! Everyone can ignore my final comment about exhaust mods only changing your wallet! :o
