Old Thu, May 10th, 2012, 08:14 PM
Aggiefishing Aggiefishing is offline
Aggiefishing is on a distinguished road
Default Installed chip! have questions
got the chip installed, love the power but have a few questions
the shifts in the daily driver are really jarring hard shifts. i was hoping it would smooth out the shifts but its bad enough that i got complaints from the people riding with me, and had to turn it to stock without the chip, the trans shifts smoothly.
the lope idle doesn't do much, what is it supposed to do?
Old Thu, May 10th, 2012, 10:28 PM
Sounds to me like it's got some transmission modifications......
The "lope idle" works on some trucks and not others. Unfortunately, it's something that (especially with 95-97 trucks or 99-03 trucks with singles) really is a hit-or-miss type of deal.
Old Fri, May 11th, 2012, 04:28 PM
the lope idle not working doesnt bother me,
i have not done modifications to the trans but i dont know about the PO, is there anyway i can find out what may have been done?
Old Fri, May 11th, 2012, 11:34 PM
Just answer me this:
Does the transmission shift noticeably in "stock"? I've been running my 95 around all day on stock tuning because it's been so long (forgot what stock even felt like), and the shifts are sluggish and soft. I mean, I can tell when it shifts, but it certainly doesn't shift with authority. If yours has a positive transition from one gear to the next, then it may have been modified at some point with a "shift kit" or valve body change (I do not and will not use the word "upgrade" for personal reasons).
Old Sat, May 12th, 2012, 06:33 PM
the transmission is super smooth in stock and the the extreme and performance tunes shift fine, but the daily is the one that is hard
Old Sun, May 13th, 2012, 08:34 AM
Looking over the tuning files that were put on the chip, that is REALLY weird. All of the ones EXCEPT the "daily driver" should be quite a bit more firm from 2nd gear on up due to the way the torque converter clutch apply is set up.
I assume you mean ALL shifts are hard, in which case there may have been a burn problem (something like that can be a one byte error out of a 229,376 byte program) and errors are not that common, but we all know how quirky computers can be. If it's only one particular shift that is annoying, then I'd like to know which one.
I'll get an RMA number from Corey and have you send it back. The chip will be reprogrammed and sent back to you.
