Old Fri, April 24th, 2009, 06:38 PM
dplummer87's Avatar
dplummer87 dplummer87 is offline
American Muscle
dplummer87 is on a distinguished road
Default HEX codes and what they mean
Ok, so that huge red sign on the main page has me intrigued...What the heck is a hex code...Did a search for HEX and returned nothing hope this hasnt been asked...
Also, groovy (or whoever) mind checkin out my stuff to make sure i got it all filled out right? This way its one less thing for me to worry about when i send my tuner in to you guys no rush.
08 F150 Screw FX4 2.5 Level KIT. Volant CAI.
Edge Programmer
Old Fri, April 24th, 2009, 07:04 PM
dlmcbm's Avatar
dlmcbm dlmcbm is offline
dlmcbm is on a distinguished road
This is a post that I started when ordering my flip chip.
http://dygytalworld.ehost-services13...read.php?t=940
hope this helps.
Chris
2001 F-350 crew cab 4X4
DIY napa air filter
4" turbo back exhaust
PHP flip chip--- stock,fuel sipper, 100hp, 140hp
Old Fri, April 24th, 2009, 07:17 PM
dplummer87's Avatar
American Muscle
hope this helps.
I already got my hex code, i just want to know what the heck it is....lars gave me a small run down. Thanks though
Edge Programmer
Old Fri, April 24th, 2009, 09:37 PM
It's not something that you really want to read off the sticker on the PCM. The hex code is an "identification" of the program that is burned into the PCM either at the factory, when the truck was built or the identification of a new dealer flash that Ford determines is good for your truck. (The new dealer flash is the reason you don't want to read the hex code off the sticker - the flash changed it). The stock Gryphon comes ready to accept a large number of hex codes (they're in a table that''s part of the Gryphon's firmware. When it reprograms the PCM to a new level using these canned tunes, the hex code is not changed, but I think the Gryphon is pretty much "married" to that hex code until it is returned to stock.
The canned tunes are very generic - sort of like Maxwell House coffee: They "wake up" any truck that they're applied to, but that's about it.
Now, when Bill writes your specific custom tunes, he "marries" those to YOUR hex code, so they won't work on someone else's truck. Part of this, of course is to keep one programmer from being used to program every truck in the world (no profit in that)! But, another, more important reason is that a custom tune for your truck COULD damage MY truck, and Bill would not want you to damage my truck with your programmer.
The custom tune is like the gourmet coffee you drink on special occasions. It's perfect for your tastes, but I possibly wouldn't like it - it could even upset my tummy!
And, if I haven't bored you enough already, the hex code is probably located in the first few bytes of the flash memory program stored in the PCM. The Gryphon can retrieve and display it using the "diagnostics" menu, as I recall.
Does this explanation help or confuse you?
Old Sat, April 25th, 2009, 12:19 AM
dplummer87's Avatar
American Muscle
Yup thanks...I used the edge to find the "hex" code and thats what i posted in my User CP...But you gave me a pretty good understanding for what the hex code is...Thanks.
Edge Programmer
Old Sat, April 25th, 2009, 01:46 AM
soutthpaw's Avatar
TIT (Tuner In Training)
Jack, Funny you mentioned damaging another truck running the wrong Hex code. I Just replied to a FTE post where the guy had got a evolution programmer from someone else and hooked it to his truck.. the first thing he did was run the return to stock option as he felt the truck had previously had a programmer ran on it before he bought it..... so he basiclly put the other guys stock program on his pcm... now his truck runs rough and only goes in reverse suggested he contact bill about getting a Gryphon as Bill can get him the proper stock tune for his truck....
you can look at this post of Bill's at dieselsite for an example of how many hex codes there are hex codes 7.3 its for the diesels but you will get the idea... some of them are interchangeable... I am not running the original hex code for my truck due to another compatible hex code having better shifting strategies.....
Back after many years.
2003 F250 CC LB 4x4 7.3PSD
Minotaur user.
Old Fri, April 24th, 2009, 07:07 PM
A hex code is the basic building block for what your customs are written from. I don't know how many there are out there. Alls I know is that you and I might have the same ones but you and your neighbor may not and all 3 of our trucks may be exactly the same. Part of it is the version of software/firmware the factory loads and if your pcm has ever been reflashed.
If Bill/Jack read this they will explain it better.
BTW they are gone until Monday.
