Old Wed, April 29th, 2009, 11:59 PM
SockTX SockTX is offline
Towing F150
SockTX is on a distinguished road
Default My Gryphon, changing trucks
I have been running my Gryphon with custom tunes on my 2004 f150 with a 4.6. I just purchased a 2006 with a 5.4. I want to put the stock (canned) tunes back in the programmer so it will work with the stock 5.4 until I get some custom tunes. I put my old truck back to stock and took out the programmer.
What next.
Thanks
Old Thu, April 30th, 2009, 12:40 AM
What next.
Thanks
I think you "fire up" Pegasus and connect your Gryphon. Then, Click on Updates->Gryphon Update Manager and, this time, accept an update to the "Calibrations". This should return your unit to stock and it should then be able to communicate with your new truck. At this point, you can find your new truck's HEX code (for the new custom tunes) and, you can program your new truck with any of the canned tunes on your "stock" Gryphon.
If, I've said anything wrong here, I'll cover the cost to fix it with PHP, so give it a try. I'm 99% sure what I'm telling you is correct.
Let me know how things work out.
Old Thu, April 30th, 2009, 01:16 AM
This is something I learned over on another forum.
I thought I knew the body classes(PCM) of these trucks but there are some additional groups.
97-2003
04heritage
2004-2008
2006-2008ffv
2007-2008
You can hook it up and return it to stock via pegasus but have Bill or Corey let you know if it's compatible. Better to know now then to not to know.
I don't want Jack having to buy "something"
Old Thu, April 30th, 2009, 10:18 PM
Towing F150
Default Swaping Trucks
Thanks for the info. My new computer wont run the program.
I will call them to be sure. I returned my truck to stock. It was a supercrew XLT with a 4.6.
My new to me truck is a Lariat supercrew with a 5.4 with 30,000 miles.
I will try to update on my old laptop.
Thanks
Old Fri, May 1st, 2009, 10:27 AM
Pegasus doesn't like 64-bit Vista at all. You CAN make Pegasus work on 32-bit Vista and the procedure is in the Pegasus manual which you can download from PHP's website. If your laptop is Windows XP, Pegasus WILL run on it.
Thanks for looking out for me Lars, but I think I'm OK here. I'm pretty sure he must have the older hardware in his Gryphon, but with a firmware update, it should recognize all the hex codes in the 2004-2008 trucks.
Old Fri, May 1st, 2009, 11:06 AM
So its the "firmware" that recognizes the pcm hex codes. I just had a bad assumption that it was something else. As long as the firmware is up to date then all is well.
