Old Thu, May 28th, 2009, 12:38 AM
JWBFX4 JWBFX4 is offline
Default Finally got to try out my tunes.
Well received my tune last week or so, but just now got to try it out since we have had rain everyday. All I can say is wow, very impressed. Definitely loving the 87 performance. It has great throttle response and the power is amazing at and around the 3000-4000 rpm range. Love the downshift when I get on it at the upper speeds also.
The only thing though, it seems that the TC is real touchy, and that it wants to lock a good bit later(but maybe thats not a bad thing, just I need to get use to it). But I may figure out what settings to play with on loosening it up a bit.
Now I know I have seen this on here before, but I can't seem to find it. On an 87 performance tune what would be the most that you could tow with it? Now I don't tow heavy loads by no means, but I am just wondering if I am getting a "light load" would I need to change it.
Old Thu, May 28th, 2009, 09:30 AM
The "tow" limit on a non tow tune is somewhere in the 2000-2500# range.
You could try reducing the TC lock/unlock speeds in the Custom Options menu and see if it feels better. That will cause an earlier lockup and delay the unlock somewhat.
Old Thu, May 28th, 2009, 02:25 PM
First off thanks for the replys...
Yea I had thought I seen that number some where posted, but couldn't remember, and also I didn't know if it mattered between the canned performance and the custom. Buts thats good to know because I usually pull about 1400# trailer once or twice a week.
Lars: Yea I had seen what you posted earlier, but I don't really think anything is "wrong" with mine....its just the speed that it locks at is my cruising speed on a lot of roads around here. So it constantly wants to lock/unlock. So I believe as long as I decrease or even increase the speed it would be just right. Just to get it to drop maybe 2 mph or so.
Old Thu, May 28th, 2009, 10:33 AM
Glad you like the tunes.
As I posted in the thread that I started(I'm impressed). I have a hiccup at about 40-45 mph. I don't know if its the same issue as yours. Bill said he was going to modify my tune after I called and talked with him. He said he was noticing it with certain possible HEX codes but was sure.
