1997 to 2003 F-150
Old Sun, June 7th, 2009, 03:15 PM
MrSub's Avatar
MrSub MrSub is offline
MrSub is on a distinguished road
Default Edge 15050
I just recently bought an Edge Evolution and love it. I went to update it the other day and got and error in the middle of it. Now it won't work. I am thinking about upgrading it to an Gryphon so when I do more stuff to my truck it will be ready for the custom tunes. Anyway is there anything I can do to get it back to the way it was. Will edge charge me to fix it? If so can I just send it in to PHP and have them upgrade it. THanks
Old Sun, June 7th, 2009, 03:27 PM
Since you posted this in the 97-2003 section, I'm guessing you have a pre 2004 truck? If that is the case, PHP is not upgrading those units to Gryphons at this time due to problems with the OBDII cables. If Edge ever gets the cable problem ironed out, they will offer the upgrade again.
And, it's possible your problem is related to the cable. However, it's kind of hard to tell from your post.
Were you trying to update the firmware using Fusion? Have you talked to Edge Tech Support about the problem? People have given good feedback on Edge's support lately, so I'd give them a try if you haven't.
Last edited by Jackpine; Sun, June 7th, 2009 at 09:07 PM. Reason: Fixed two stupid typos!
Old Sun, June 7th, 2009, 03:35 PM
MrSub's Avatar
I have not talked to Edge yet because they are closed. I was in the middle of updating the unit via the USB cable over the net. That is where I got the error. When I plug it into my truck it just lights up. Nothing comes up on the screen and when I try to update it again via USB it says it is in Run mode or corrupted memory.
2003 F-150 FX4 Reg. Cab Shortbed
5.4L w/ Headers, K&N CAI, True Dual Flowmaster w/ Tipdowns
Old Sun, June 7th, 2009, 09:10 PM
OK, all is not lost. DO talk to them. I'm sure they can talk you through a repair that will have you up and running again.
One note: Bill recommends that unless you are having problems with the unit, that you do not try to update the firmware in the Edge. In other words, if it ain't broke, don't fix it!
Old Sun, June 7th, 2009, 09:11 PM
MrSub's Avatar
Do you give new cables for the truck when you upgrade them or use the ones that come with
Old Sun, June 7th, 2009, 09:14 PM
Is it the cable for the usb update or the cable for the truck that is junk.
Looks like we were posting at almost the same time. It's the OBDII cable that's the problem, but, even if yours seems ok now, there's no guarantee it will continue to function properly. And, PHP does not want to take "ownership" of the warranty on faulty cables. (They also don't want to sell faulty equipment).
Old Mon, June 8th, 2009, 04:42 PM
MrSub's Avatar
Called Edge today and they fixed it online for me. Won't do that again. THanks for all the help guys. Will be checking back often to see if you guys will update to the gryphons again. Thanks
