Old Fri, June 26th, 2009, 02:09 PM
PoisonXA PoisonXA is offline
PoisonXA is on a distinguished road
Default help
I have a question.
what custom settings can i change if i use 93 perf canned tune.
with full dual exhaust and 305,45,r22 tires.
and i always use 93 octane gas.
in other words what adjustments can i make while i wait for my custom tunes. Thanks ahead of time.
Old Fri, June 26th, 2009, 03:00 PM
Originally Posted by PoisonXA View Post
I have a question.
There is a lot you can do as far as adjusting shift points, shift firmness, and other things.
Old Fri, June 26th, 2009, 03:02 PM
BlackSTX's Avatar
BlackSTX BlackSTX is offline
Baconator
Well, you could probably bump up your timing a degree or two to get the max benefit of the additional octane, but I'm not too sure I would really bother with much else at this time. Shift firmness can be changed to your liking, octane won't make a difference there.
Old Fri, June 26th, 2009, 03:45 PM
Read through the gryphon Q+A also
Old Sat, June 27th, 2009, 04:43 PM
i just wanna know what you guys have done while you wait. like for instance where to put the shift points and firmness and etc etc i just wanna know what you guys have done.
Old Sat, June 27th, 2009, 05:09 PM
What WE have done will not be right for you.
But, IF you use level 3 and IF you fill with 93 octane, you should be able to add +1 degree of timing. You may want to set your 1-2, 2-3 WOT shift points at or near 5000, and the 3-4 WOT shift point around 4500. Set the Max RPM to 5400.
Some people like to increase the shift firmness, I didn't. Those that do seem to use around +10 for 1-2 and 2-3 and around +6 for 3-4.
Stresses on the 3-4 shift are the highest, so don't be aggressive on that one.
I reduced my part throttle up and downshift speeds and TC lock/unlock points to save gas. You might want to do the same or increase yours to improve on part throttle power.
And, as Lars said, read through the "Custom Options Q & A" too. You'll find it here: http://dygytalworld.ehost-services13...ead.php?t=1101
Old Sat, June 27th, 2009, 06:14 PM
What did you set it to to, save gas?
