Towing
Old Thu, July 2nd, 2009, 03:06 PM
JFolmar JFolmar is offline
JFolmar is on a distinguished road
Default max towing capacity for 87 performance
i have a 2001 f150 supercrew. how much can i tow on 87 performance. or should i just put it back into can tune 87 tow???
Gryphon-87 Performance
Magnaflow SI/SO
K&N FIPK GEN2 Intake
Westin Bull bar
Lightning Taillights
Eagle Deck Lid
15% Tint
285/70 Firestone Destination AT's
Old Thu, July 2nd, 2009, 03:57 PM
#2500.
Don't really know if this includes payload also.
GC beat me to it!
Old Thu, July 9th, 2009, 08:30 AM
TXWolf's Avatar
TXWolf TXWolf is offline
Native American Redneck
TXWolf is on a distinguished road
Is there a weight limit on a Gryphon custom tow tune?
http://dygytalworld.ehost-services139.com/forums/image.php?
2008 F150 Supercrew Lariat 4x4
5.4L - 4.88 Gears
PHP Gryphon Programmer - BDS 6" Lift - Magnaflow Dual Exhaust - JLT Ram Air Intake - 20" Pacer Ridgeline Rims with 35" Mickey Thompson Baja ATZs Tires - Westin BullBar with Driving Lights
Old Thu, July 9th, 2009, 10:01 AM
And, TX, in your case, you would want Bill to know that you are pulling a HEAVY load, so he can optimize the tow tune for it. Your trailer will have a spec sheet that lists the unloaded vehicle weight as well as the weight added when you fill the fresh water tanks and have full propane cylinders. (You're probably mostly going to pull that thing into "civilized" campgrounds where freshwater is available, so you may want to leave those tanks empty). You'll need to add a bit of weight for whatever else you put into the trailer too, such as food and clothing. So, DO let Bill know what the actual approximate towed weight of the trailer is, when you ask for a custom tow tune.
Old Thu, July 9th, 2009, 12:42 PM
TXWolf's Avatar
Unfortunately, Bill's already written a custom tow tune. At the time that I upgraded to the Gryphon, I didn't know that I would be pulling a big travel trailer. I think that I talked/emailed with Corey, and at the time a boat was the biggest thing that I was towing.
5.4L - 4.88 Gears
Old Wed, July 15th, 2009, 08:33 PM
TX, I think you need to get a custom tow tune for that weight! If you have not already loaded the one Bill wrote, (and you may have told me, but I forgot), the canned tow tune would be much better for you.
You need to check this thread out: http://dygytalworld.ehost-services13...ead.php?t=1314 and, talk to 408F150 and 06KingRanch. They have similar towing requirements.
I'd love it if you all could discuss this out in the open, so we all can see it, rather than in PMs. I think there's a lot to be learned.
And, I'm going to see about starting a "Towing" forum. If it flies, I'll probably move all this to the new forum.
Edit: The new forum is set up and this is there.
Last edited by Jackpine; Thu, July 16th, 2009 at 12:59 AM. Reason: Moved to new forum.
