Old Sat, July 25th, 2009, 12:00 AM
not you not you is offline
not you is on a distinguished road
Default have a question
i bought a gryphon with trans only 87 tow and 93 performance what can i expect from these picks i think i might have screwed up my truck is bone stock except a drop in k n filter i looking for better mpg and and better shifting and maybe to spin some tires when its not raining i can tell i will be messing with this thing alot oh i never tow with this truck so is the 87 tow useless to me please help me figure these thungs out thank u
Old Sat, July 25th, 2009, 09:18 AM
Sounds to me like you should get an 87 performance tune instead of an 87 tow. What I'd do is put the 87 performance on Level 1, Leave Level 2 alone as the canned tow tune and replace Level 3 with your 93 performance tune.
Old Sat, July 25th, 2009, 09:35 AM
say what? i guessing on each tune there is settings?
Old Sat, July 25th, 2009, 09:42 AM
There are, but most of them are done by Bill. This is what a "custom" tune is all about. It's not you making "trial and error" inputs that might cause your engine to blow up, or your transmission to fall apart.
Old Sat, July 25th, 2009, 10:21 AM
yes thats what i do not want to happen . groovy chick said they might ship on friday(yesterday) so what can i do now? wait to get it and wait in line for custom tunes? can i still use it ? will it make a difference with the mpg and spining some tires or not do anything and hurt the truck and we dont want that ( i would not want totell the wife that i just screwed the brand new truck up ) thanks with the feed back and be prepared for more shawn
Old Sat, July 25th, 2009, 10:51 AM
OK, I THINK you are asking questions about the "Custom Options" feature of the Gryphon/Edge. If you're just getting a new Gryphon, it will come preloaded with Bill's "canned" tunes. These are better than Edges' but he can customize them for your truck and driving goals still more with true custom tunes. The three tunes are 1. 87 Tranny only, 2. 87 tow, and 3. 93 Performance.
If your tank is FILLED with 93 octane, you can choose this tune. If not, I'd try the 87 Tow tune. The first time you set a tune, skip the Custom Options menu completely. This lets the Gryphon build some files it needs.
Drive the truck around and find out what the tune has done for you.
Then, if you want to make small adjustments, you can reenter the tune, but this time choose the Custom Options menu. Before you do this, read through the Q and A about this menu here: http://dygytalworld.ehost-services13...ead.php?t=1101 Read through this several times - make sure you understand it. It's VERY easy to misunderstand what you're doing and screw things up.
I'd also be very reluctant to set any WOT shift above 5100 and don't move the max rpm above 5500, to avoid transmission damage. I'd also probably not increase shift firmness much above +10.
Old Sun, July 26th, 2009, 08:15 AM
Circuit Circuit is offline
Circuit is on a distinguished road
That is exactly what I did.
I did so much research on programmers now I can't wait to get it!
In my '04 SCAB 6.5' bed with a 4.6 doing the calculation myself as said above I get 17-18 now driving medium (I am not too hard but not slow either). I get 1000 kms per tank. I do have the big tank.
Our F-150's are full size trucks. My daily driver gets 4-6 mpg. It's a tri-axle dump truck with a pup hauling 37 tons.
2004 XLT SCAB / 4.6
Current: In bed lighting, K&N Drop-in, Gott's intake mod, Gryphon custom tuned
Future: Exhaust (next), UDP, eFans
