Old Mon, December 29th, 2008, 06:07 PM
jerodr's Avatar
jerodr jerodr is offline
jerodr is on a distinguished road
Default Issue with dtc codes
Well...I was washing my truck earlier and I got in it to turn it around in my driveway, cranked it and an "Engine in failsafe mode" beeped on my message center. Scared the Sh** out of me. So I turned it off and checked the dtc codes on my gryphon. It pulled one - P2106: Throttle Actuator Control System - Forced Limited power. So I thought ok i'll just return it back to stock and see what happens. Did that and now I have a different code only - P1000 On-Board Diagnostics System: Readiness Test not complete. The "engine in failsafe mode" isn't on anymore, but I am still getting this code. I unpluged the gryphon and plugged it back in but the code is still there. Any help would be greatly appreciated.
Jerod
04 Screw Lariat--Magnaflow SI/SO-- PHP Gryphon--AS 2"--BFG ATs 285/65/18--
Silverstar Heads and Fogs
Old Mon, December 29th, 2008, 07:01 PM
Jerod
I'm pretty sure you're getting the P1000 code now because the system's been returned to stock and you haven't completed the required number of drive cycles (which is a good reason to NEVER return it to stock just before an emissions test (if your state requires them and they plug their tester into your OBDII port). Just leave it in it's custom tune and all seems to be well (according to several other Gryphon owners who've had their car emissions tested). I plan to remove my Gryphon from the dash though, when it's my turn and tuck the cable up out of sight - so I don't give the test folks anything to raise their eyebrows over.
Now, why did you get the failsafe warning and the P2106 code? I can only guess. Did you perhaps wash the engine? I've learned these trucks are pretty sensitive to water in and around the COPs. It's possible something like that caused the trouble - especially since the truck was fine up until you washed it and it was simply sitting there under no stress. The failsafe mode is activated though by high engine temperatures and that information comes from the CHT sensor I believe. Possibly water in and around it caused it to send an erroneous high reading to the PCM, forcing the failsafe mode.
If it was my truck, I'd go out and reprogram the tune you had before. Start it and see what happens. I suspect you'll still have the P1000 code, but that should go away after about 30 miles of driving.
Anyone else with some more brilliant thoughts?
Old Mon, December 29th, 2008, 07:11 PM
jerodr's Avatar
Jack..I did not wash the engine. I didn't even raise the hood. That is good news about the p1000 code. However I am not sure about the other code. I plan on trying to reprogram back to level 2 like you said and see what happens. I wonder if it has anything to do with my throttle lag still being there after the tune like I mentioned in the other thread? Thanks Jack you're a ton of help.
Jerod
Old Mon, December 29th, 2008, 07:26 PM
Well heck, I hate it when I can't be brilliant! :cry:
Again though, the failsafe mode is only "real" when the engine overheats. For some stupid reason then, I'd have to say it got a false "hot" signal from the CHT sensor. (This shuts down fuel injection and possibly spark on every other cylinder - but air is still brought in to cool things down).
Since the engine was clearly NOT hot, it had to be a false signal, and, I suppose it's possible for CHT sensors to fail suddenly, and maybe to the HOT status, but I'd think it unlikely. I'd also be surprised to see that code go away just because you reprogrammed the PCM to Level 0, if the sensor was bad.
I'll be most interested in learning what happens when you return the tune you had before. I am absolutely positive a tune cannot cause this failsafe symptom! (And if it turns out it can, I'll never give anyone advice again). :sniffle:
(I meant to add - If you continue to have trouble on the Level 2 tune, post your problem in the "Help - Emergency" forum. I think Bill would want to know about it right away! And, I suspect he monitors that forum pretty closely).
Last edited by Jackpine; Mon, December 29th, 2008 at 07:30 PM. Reason: Added note to use Emergency forum if problem continues
Old Mon, December 29th, 2008, 10:04 PM
jerodr's Avatar
Well...I programmed everything back to level 2 and went out and ran some errands and everything seemed ok. When I got home I checked the dtc codes and there were none so everything "seems" to be back in order. I'll keep driving it and hope that everything goes ok...not really sure what happened. Thanks Jack for your help.
Jerod
Old Mon, December 29th, 2008, 11:06 PM
Yea, well - I'm really glad to hear you weren't blown up or anything following my half-baked advice! Honestly, I'm not an "expert" on these things at all, but, I DO read and I try to apply what I've learned in engineering to these problems. I also never advise anyone to try anything I wouldn't try myself.
But, now I have to tell you a tiny story about how I decided something in a single-lens reflex camera I had many years ago needed cleaning. It actually did need this treatment, but in the process, I totally ruined the semi-transparent mirror this particular Canon camera had. Bottom line was a fairly large repair bill to Canon to fix my fix! :o
So, I try to reason things out correctly - but, I'm afraid I get things wrong all the time!
And, I suspect when Bill gets a free moment or two, he'll inject his usual brilliance here to tell us what REALLY happened!
(AND - HE DID! So, did you "cold start" and slam it quickly into gear? I can't help but wonder though, why this action would put it into failsafe???)
Last edited by Jackpine; Mon, December 29th, 2008 at 11:11 PM. Reason: Acknowledgement of Bill's input (before mine).
Old Mon, December 29th, 2008, 10:54 PM
Jerod
Check this. It's quite possibly related to your issue.
http://www.ford-trucks.com/tsb/fullt...p?tsb=05-18-12
As for the P1000, that is completely normal and should go away after some normal driving, although it may take up to a couple days to make it go away.
If the P2106 occurs again, shut the truck off, restart, and then go into the diagnostics menu and clear the DTCs. This should clear everything out.
Hope this helps.
