Old Wed, August 5th, 2009, 07:51 PM
ean's Avatar
ean ean is offline
ean
ean is on a distinguished road
Gryphon issues ?
I Know i have not got my custom tunes yet but do you really think they will be way better than what i am getting on the can tunes? right now i am really not impressed with the milage that I am getting with the can tunes. I was getting 2-3 more MPG running a max energy hypertech. any help please. and all i read is how everyone is so happy with theirs and why am I not?
Old Wed, August 5th, 2009, 09:54 PM
There could be a few reasons:
1. The Hypertech's tunes are better than the Gryphon's canned tunes. (There, I said it!)
2. The Hypertech was biased more toward economy and the Gryphon is biased more toward performance.
3. Your driving habits have changed?
4. You are relying on the Average Economy display in the Gryphon instead of doing a "hand calculation".
5. The Tire Size on your vehicle was incorrect after programming with at least one of these devices. (Possibly both.)
Of all the reasons I've shown above, Nbr 5, incorrect Tire Size (TS) is my favorite. I just did a quick lookup at the Hypertech Manual for their Max Energy Econ model, and I notice you have to pay extra to be able to correct the speedometer. Did you get this feature?
If not, is your TS and Gear Ratio (GR) stock? If not, you WILL have to correct these - in either the Hypertech or in the Gryphon. Now, it gets tricky:
A. If you have non-stock tires or gears and did not correct for these with the Hypertech, any MPG you calculated would be wrong.
B. IF you "opened" the "Custom Options Menu" in the Gryphon and DID NOT enter correct values for TS and GR, your fuel economy would be wrong (probably low).
C. IF you have non-stock tires or gears and did not adjust for these with the Gryphon, your fuel economy would be wrong (probably low).
And, even if you do have stock tires and gears and opened the Custom Options Menu - If you DID NOT "set" your TS and GR, you are probably going to see low values for economy.
So, think about all this, and let me know what's going on.
Old Wed, August 5th, 2009, 10:24 PM
ean's Avatar
ean ean is offline
ean
GR is stock but you are right I have not yet done the tire size on my gryphon maybe thats throwing it off. I will program TS and Try That to see if it helps.
Thanks for your help. do you know what invoice # the are working on because in update its showing 0000?
Old Wed, August 5th, 2009, 10:36 PM
ean's Avatar
ean ean is offline
ean
I got 4344 for tire size is that right or does my math suck?
Old Wed, August 5th, 2009, 11:37 PM
Question
4344? You got a monster truck?
Please post the tire size? It will let us help you better!
Also there is a tire size calculator in Pegasus.
Please also enter in your information into the user cp such as hex/calibration code and serial number.
Thanx
Old Thu, August 6th, 2009, 12:27 AM
ean's Avatar
ean ean is offline
ean
my tire size is 35 /12.50/20 with stock gear ratio that will help out. { did enter hex / clibration and all that stuff and it is showing invoice # 0000 and update 0/00/0000 for last update
Thanks
