I currently own an Evolution EEF2100 and I am unable to get to the Custom Options to set gear ratio and tire size. Edge Customer Support told me that it may be because the PCM doesn't give them the option to adjust that parameter. :weeping:
Here is the message to Edge below: I'm having issues getting my Lightning software to connect to the update server to see if there is an update for my EEF2100. I am currently using Version 2.00.0072 Lightning software. I'm currently using bootloader v1.00b Firmware v08 and Calibration v08. The reason I'm trying to update my Evolution is because I am unable to get to the "custom options" where I am able to change gears and tire size. No matter which level I program into my truck I'm unable to get to the custom options. I've had it programmed at level 3 and then selected level three again and it tells me to turn the key off and back on then it begins programming level 3 back into it. Never does it give me an option to customize it. Here is their reply: Robert, We can try to walk you through the update process when we reopen on Friday the 2nd. If you can call at that time or the following week we can try to walk you through the update process. The only problem is that we may not be able to do tire size programming on your truck. If the Evolution doesn't give you that option after the update, it may be because the vehicle's PCM doesn't give us the option to adjust that parameter. Please let me know if you have any additional questions. Thank you. Bill- is this true, that some PCM's will not allow the custom options? If so, I would think they should mention that in the manual for my EEF2100. When I upgrade this to a Gryphon will I be able to access the custom options then? BTW, I have also loaded V076 firmware and v7 calibration, also with no luck. Specs: 1997 Ford F150 5.4L Auto 2wd HEX Code: ALAPKD3 Thank you in advance. ![]() Rob Last edited by slammedsplash; Wed, December 31st, 2008 at 01:05 PM. Reason: Including Truck Specs |
Glad to see you've made it over to here Rob. I DO know that the pre-2004 trucks had PCMs that were more limited in what you could monitor and maybe even adjust. I too, would have thought though that tire size and gear ratio would be available. The Mad Doctor (Bill) will be able to help you, I'm sure, just as soon as he gets to your post. You might want to go back and edit it to include your model year (1997) and engine info though.
That was a GOOD title you used! It should get his attention! - Jack
Thanks Jack, I was hoping that title would get Bills attention. I know he is busy trying to get everyones custom tunes out. I have went ahead and edited my post with the truck specs.
- Jack |
Not to split hairs here, but this is out of Edge's manual for the 1997-2003 Evolution (Page 20):
As for the custom options themselves, it was most likely an oversight that there are no options for the ALAPK family because there are some for the ALAPF family. If you plan to upgrade to the Gryphon, we will make sure to have those options included in your build. Take care and have a Happy New Year!
