Old Tue, August 11th, 2009, 08:44 PM
mkf350 mkf350 is offline
mkf350 is on a distinguished road
Default Need Help (after hours)
After using chip for a few days decided to try some other tunes.
With truck off I removed chip and switch.
Inserted chip into programmer.
Connected usb cable.
Connected power supply.
opened software.
selected new tunes
verify chip is in pos 1.
verify program is in 6-position chip.
clicked on write to chip, goes through loading tunes then click ok to erase chip and i get an error"The module was not either placed in pos 1 or is not properrly formatted as a multi position module".
check diagnostics and multi authority bit =FF
tried reseating chip no change....
Thanks Mike
2002 F-250 CrewCab LB
AFE ProGuard 7 intake
4" Magnaflow ss exhaust with 4" downpipe
BTS Trans Valvebody
Dieselsite Adreneline HPOP
Garret GP38R turbo
PHP Phoenix FU
Old Tue, August 11th, 2009, 11:28 PM
I will let someone know of the problem.
Old Tue, August 11th, 2009, 11:39 PM
Thanks Lars.
mkf350, did you put the programs on the chip that you have been running for "a few days" or were they on it when it arrived from PHP?
Usually, you should erase before attempting to write. I don't have the package you do though, so I hope that Bill can get you going.
Old Wed, August 12th, 2009, 12:13 AM
Mike,
Not sure what happened there. It sounds as if the chip might have lost the formatting, but not sure as to why.
First question... When connected and the software is open, what are the PID, CID, and FID in the lower right corner of the application?
Second... At this point, does the chip still work in the truck or is it completely unusable?
Let me know where we're at and I'll get a new chip out the door for you.
Thanks.
Old Wed, August 12th, 2009, 08:15 AM
Bill,
Here is what I have...
Chip still is usable.
BTS Trans Valvebody
Garret GP38R turbo
PHP Phoenix FU
Old Wed, August 12th, 2009, 07:37 PM
Ok will do.
BTS Trans Valvebody
Garret GP38R turbo
PHP Phoenix FU
