Old Mon, August 31st, 2009, 09:13 PM
eabrust's Avatar
eabrust eabrust is offline
electro-mechanical geek
Default Rough running with updated FICM
Looking for some help from Bill or anyone else that has done FICM updating on their truck.
I got a spare FICM off Ebay (a model year '04 module) that had the latest Ford flash on it. Had it in my truck ('06 F350) for a little over a week driving around town to check it out prior to sending off for reflashing. Had no issues, it worked great, so I figured the module must be OK and sent it in for FICM reprogram, got it back pretty quick (thanks Bill!).
I finally tried installing the reprogrammed module in my truck this last week. On first start in the morning, and starting up to go home from work in the afternoon, the truck would lope and idle poorly, and in general run rough like one or so injectors weren't quite working right. After a few minutes, the loping idle would cease, but heading out on the road the truck has no power and stumbles, still as if an injector isn't quite doing its thing. Fuel mileage was also suffering. After the truck was up to temp, it would run just great, had great drivability, and seemed to have no issues.
I gave it a few days to see if it would resolve itself or if the PCM had to 'relearn' anything, truck never threw an CEL and continued to run crappy, and finaly removed the reprogrammed FICM and put my original back in. Truck runs great out of the chute every morning with the stock FICM and program, never a stutter, so I know the issue is tied to the FICM, not to individual injector(s).
I pulled apart the reprogrammmed spare FICM, to see if I could find any issue relating to the modules behavior (smoked resistors, cracked solder joints, etc.) and couldn't find any issues. The DC convert coils and caps all looked OK, and the driver side looked OK to. Pics attached if anyone is curious what is in a FICM.
So I guess my questions are:
1) Does the PCM have to relearn anything w/ updated FICM for some length of time (ie, did I pull the module to quick?)
2) Is the updated programming pretty much canned for any and all trucks, or does it depend on what strategy is in the PCM? My truck was in the shop a week or two ago, and I know they reflashed both my PCM and my stock FICM recently. Is it possible a slightly different program would work better on my truck?
3) From what I read, the behavior of the FICM to work better as the truck heats up seems to match what people find as the module is on its way out, is that the case? (would be my luck the FICM would die just after getting a proper program put on it....) I was hoping to find an issue in the FICM, but couldn't see any indication, looking at all components solder joints under magnification.
Thanks for any insight anyone can provide.
Regards
Eric Brust
Old Tue, September 1st, 2009, 08:56 PM
lbjailer's Avatar
lbjailer lbjailer is offline
08F150LARIET
lbjailer is on a distinguished road
I experienced a similar event the other day with my 08 F150. It was hot outside, (temp registered 115 on the truck dash display) I traveled a short distance, truck seemed like it wasn't firing on one of the cylinders. Drove about 3 miles, stopped and less than 10 minutes later got in the truck started it up and runs fine. There were no diagnostic codes on the Gryphon, and everything seems ok, but will have dealer check my plug wires and check my CAI screws and make sure they aren't loose.
Old Thu, September 3rd, 2009, 07:52 AM
Mine has done this also. Once this spring on a snowy wet slushy day and this summer with the truck being in the garage for 2 weeks, no rain and not humid that day.
No tunes and no cai.
Old Thu, September 3rd, 2009, 10:59 AM
Jeremy's Avatar
Jeremy Jeremy is offline
Spark Plug Inhibited
Boy that sucks, I've been leary of used FICMs because of the damn heat inductive flash killing them left and right, you may have bought one that was on its way out. New ones from ford are ~$475 now, i guess with all the failures, ford lowered the price.
19 F-350 6.7 Auto
16 F-350 6.7 Auto
Old Thu, September 10th, 2009, 09:20 PM
eabrust's Avatar
Default Still checking out truck
Well, per an email I got from Bill, it was suggested that I could monitor the voltage from the access port directly rather than use a scan tool (why didn't I think of that myself?!). He said he'd get me instructions on what to do, but I know he's busy, and I know electronics enough to just go do it.
So I went ahead and made measurements of both my stock (good working) FICM and my PHP tuned FICM which is giving me some issues. I attached a link to a PDF documenting what I did for reference, should it help anyone else out. I used long enough test lead wire to let me sit in the truck and rev the engine during testing also. As a side note, if any of you want to go testing your FICMs, be very careful, I don't want to hear anyone say they smoked and broke their modules because of me
Long story short, the DC output on both of my FICMs is right at 48+ volts, so it doesn't appear that the FICM is suffering a slow death from the power supply side. It could be a problem on the driver board side, but I wouldn't think that would tend to clear up as the truck warms up, which still leaves me thinking there is some software strategy conflict that may be resolved by another software load.
Still hoping to hear from Bill any further suggestions or if he has any ideas on software conflict possibility. If anyone has any suggestions to the attached PDF let me know, or if anyone finds the attachment useful for future reference, feel free to use it or make it a sticky here on this forum.
The PDF is a 2.3MB file, so I linked to it.
Link:
http://www.mediafire.com/?sharekey=a...4e75f6e8ebb871
Thanks
Eric
2006 F350 King Ranch
Gryphon & PHP tuned FICM
EGR deleted
4" Turboback
Old Sun, September 13th, 2009, 03:54 PM
classic trucks classic trucks is offline
classic trucks is on a distinguished road
Default similar issues
I had Bill redo my ficm.The truck runs fine on interstate or 60+mph but I have cold start issues especially with the weather cooling down. I also have the heavy loping on start up and long warm up times. I have noticed a skip at lower speeds (40-50) in traffic especially up hills. I don't have an extra ficm to swap in and didn't have problems before the reprogram.I took my tuner off and the issues are still there. Any suggestions?
Old Wed, October 14th, 2009, 02:24 PM
Treb Treb is offline
Treb is on a distinguished road
Thanks!
eabrust
That "Testing FICM Power" "how to" you made is fantastic. Thanks. I saved and printed that one. It will come in handy. I have an 04 FICM waiting to be tested and sent to PHP if it checks out okay.
Thanks again,
Treb
Old Wed, December 2nd, 2009, 08:06 AM
apeelectric apeelectric is offline
apeelectric is on a distinguished road
Default FICM trouble
I was having the same trouble with an 2005 with PHPs tuned FICM put stock one back in now the truck is running fine I think there must be a programming problem I will try to call PHP to get info. Also my truck did not shift right after installing new FICM Bill said it should have nothing to do with FICM but with stock FICM all my troubles went away .
Old Tue, September 1st, 2009, 09:27 PM
Jeremy's Avatar
Whenever I've had issue with the FICM and it was usally when I had just changed it out, was because I did'nt have the plugs all the way in. I've learned to listen to the two distintive snaps from each plug, to make sure they were in all the way. I also put dielectric grease on the rubber seals on the the FICM, it makes it easier to remove next time it has to come off. I've had then run on 7 cyl, and only 4 at times from the plugs not being in right.
The other reason was I had Innovative's tunes on my SCT X3, and they did'nt like the FICM on cold morning starts(0F-30F. The truck would start, and run rough for about 2 minutes then die. You could restart and it would be fine once it warmed up. Removed the SCT and it was fine.
I'd put it on one more time just to be sure. After all its only a five minute swap.
keep us posted.
Regards
Eric Brust
19 F-350 6.7 Auto
16 F-350 6.7 Auto
Old Wed, September 2nd, 2009, 01:08 AM
NHRA6002 NHRA6002 is offline
NHRA6002 is on a distinguished road
Regards
Eric Brust
I'm having the same issue with mine since the new program was installed in Monroe WA.
Any thoughts?
05 6.0L CC DRW 4X4 Lariat FX4
4" t/b Magnaflow and Evo installed April 13/09
