1997 to 2003 F-150
Old Wed, September 16th, 2009, 01:34 AM
RobbyMartin RobbyMartin is offline
RobbyMartin is on a distinguished road
Default Throttle response?!?!
I was wondering if any of you guys have experienced a lack of throttle response similar to what turbo lag would be? When I mash the gas the truck hesitates like it has swallowed too much air and then seems to catch up with itself.
I've cleaned the MAF and air cleaner, I've replaced the DPFE, EGR, Plugs, IAC and it runs better but still hesitates. I have a Hypertech Power Programmer III installed and I'm afraid thats the issue but I don't know for sure. I DO plan to purchase the Gryphon but in the meantime I'm trying to solve this issue. Any suggestions?
2002 F150 Supercrew 4.6L (Airaid intake and 3" T-Flow exhaust and Hypertech PPIII)
Old Wed, September 16th, 2009, 05:56 AM
Throttle position sensor?
Old Wed, September 16th, 2009, 12:26 PM
fordkindaguy's Avatar
fordkindaguy fordkindaguy is offline
Wanna go fast
fordkindaguy is on a distinguished road
Fuel filter possibly? Take the hypertech off and run it stock, see if that resolves your lag problem. By the way, just get the gryphon either way in the end its better!
Old Wed, September 16th, 2009, 02:29 PM
Robby, I had the same complaint when I first got my 2005. There'd be this "pause" (what do I do now?) thing anytime I stepped on the gas to pass someone.
As soon as I applied the canned tow tune when I got my Edge (now a Gryphon), that went away. To me, that alone was worth the cost of the programmer!
Things have only gotten better with custom tunes of course.
Old Wed, September 16th, 2009, 02:50 PM
Yes good answer!
Forgot about that one!
Also check the fuel pressure regulator and pressure at the fuel rail.
Being you own a 97-03 you have a cable TB and when I had mine I never had any lag.
Old Wed, September 16th, 2009, 04:07 PM
Yes good answer!
I forgot to mention that I replaced the fuel filter as well and that didn't cure the problem.
A few years ago I replaced the fuel pump and that didn't change anything either but what I did notice was the fuel gauge reading would change. I used to get about 200 miles or more at half tank and now I'm lucky to get 175. At empty, i am lucky to get 290-300 when i used to get 325-335. What could be the problem?
As far as the Gryphon, I use my truck as a daily driver and I want throttle response and fuel economy. I rarely tow but if I do it's about 2500 lbs. or less. I never have a need to race it since its lifted with 35" tires. With that being said, what tunes should be purchased with a Gryphon?
Old Wed, September 16th, 2009, 04:18 PM
You probably need only the 87 octane performance/economy tune. You've pretty much defined what you're looking for in the tune with your post. It's probably pretty close to what I asked for: Good highway passing performance and any improvement possible on gas mileage.
However, since you've got the big tires, you've effectively reduced your gear ratio. I wonder if Bill could write a custom tow tune that would help you even when you're towing THOSE loads? Since tunes are only $30, seems like maybe a reasonable question to ask him.
Old Wed, September 16th, 2009, 04:48 PM
When you lifted the truck and put the big rubbers on is that when you noticed the decrease in mpg's?
Big tires=-mpgs
Regearing can get some of the mpgs back, but not all of them.
What the gearing on the truck now?
And definately a custom tune will help.
